FS: '98 Camaro Z28 M6 Vert. (racecar)
SOLD!!!
1998 Camaro Z-28 Convertible M6 (I consider it more race car than DD)
Forged 383
White w/ white top
Interior was white leather, replaced w/ dark leather.
The rest of the photos can be seen at:
http://www.putfile.com/album/180245
$8500
Here's the story in a nutshell.
I bought the car with a blown up engine a few years ago. The top and interior weren't in good shape. I replaced the interior (hated replacing the white leather, but the seats weren't in that good of shape) and chose to only drive the car when it was warm so the top couldn't be seen.
I had the original motor rebuilt with stock crank, eagle rods, and probe pistons. I put 243 heads on that had been ported by Wells Racing, and put a Fast 90 setup up top with all supporting bolt ons. This setup got me 94.50mph on motor and 105mph on 150shot out at redline just playing around (I know everyone says this, but I truly wasn't running the car too seriously). I ended up cracking a cylinder a week later (don't know why, just started smoking out valve cover) so I pulled it all apart, sold that short block and replaced it with current 383.
I just finished the car a few days ago and the engine has about 35min. of runtime on it and 10min of driving on it. It is definately all there.
Buyer is welcome to come drive and ride in the car.
I consider it my race car because it's not my DD, and it doesn't have all the comforts a DD would have. No A/C, no front Sway bar, top is ugly, rod end rear suspension parts make noises. Car does drive tight and straight though.
I have put lots of money and time in the car, and I don't have to sell it. But would like to focus my time on my dirt car.
I beleive I could peice the car out and get near this amount without including the actual car itself.
GENERAL
Chrome ZR1 Wheels – 17x9.5 front, 17x11 rear (nice shape)
275/40/17 Ventus Z-rated tires on front
315/35/17 Nitto 555R Extreme Drag radials on rear
Vogtland 1¾” lowering springs
TRANSMISSION
Ram Powergrip HD Clutch (good up to 600rwhp)
Ram Heavy Duty Steel Billet Flywheel
B&M short throw shifter
Drill Mod
Ram Adjustable master cylinder
2001 Slave Cylinder
BOLT-ONS and ACCESSORIES
Pacesetter long tube headers – race style
Pacesetter off-road Y-pipe
Race Ready’s electric cut-out (mounted right at y-pipe)
Stock cat-back exhaust (Did this to be stealthy when you need it, then be loud and free flowing when you want to rock)
Fast 90 Intake
Nick Williams 90mm Throttle body
ZO6 85mm MAF w/ adapter harness
Katech serpentine belt tensioner
ASP under drive pulley
Hypertech 180 thermostat (have 160 and stock if needed)
Casper’s fuel pump wiring upgrade kit
Walbro 255 Fuel pump
SLP Fan control wiring harness
LG lid
Bosch 13111 o2 sensors
Hurst Roll-control kit
Keith Craft LCA Brackets
Chromoly adjustable LCA’s
Chromoly adjustable Panhard bar
Hotchkis HD Rear Sway Bar
Hawk Brake Pads – front and rear
ENGINE
Built by Wells Racing Engines, Duncanville Tx.
Eagle 4340 Forged crank 4.00” stroke
Eagle 4340 6.125” H-beam rods w/ ARP rod bolts
Diamond Forged Pistons, 2-eyebrow w/ rings nitrous gapped
Compression 12:1
Clevite race bearings
Katech LS6 oil pump, ported & shimmed
Double roller timing chain
LG Motorsports G5X4 Camshaft
LS7 roller lifters
Comp Cams 921 valve train kit (double valve springs good to .660 lift (checked on spring checker – good to .690 lift), titanium retainers)
Comp Cams Magnum pushrods 7.400 length (same as stock)
Ported and Polished 243 LS6 Heads, flat milled .030
Fererra Stainless Valves 2.02 Intake 1.57 Exhaust
ARP head bolts
ARP main studs
New water pump
Fel-pro gaskets in motor
Cometic .040 head gaskets (.012 thinner than stock)
NGK TR6’s (gapped at .036) for nitrous
NITROUS KIT
TNT F2 nitrous kit (dual fogger 90mm throttle body ring)
Jets for 100, 150, 200, 250, 300, 350 wheel horsepower
TNT Purge kit
MSD 8969 Digital window switch
TNT bottle heater
NOS Fuel Pressure Safety Switch
Nitrous Outlet tunnel mount for nitrous bottle (not installed yet)
Nitrous Outlet WOT trigger switch & mount
DATA LOGGING AND TUNING
A-pillar gauge pod with:
AEM wideband gauge (white face)
Autometer Phantom electric fuel pressure gauge (white face)
HP Tuners Suite (4 credits left)
Jotto Desk Laptop mount (purchased from Cop Stuff)
FLUIDS
Redline Synthetic power steering fluid
Mobil 1 15w-50 motor oil
Valvoline ATF transmission fluid
MISC
Wig-wag box for headlights, alternating pattern
Wig-wag box for taillights (victory lights)
Stuff Removed
!EGR/AIR
!Spare tire (still have)
!A/C (still have system)
!Front sway bar
!Rear seats (still have them)
!CAGS
Car is registered and inspected as of this week. Will be good for a year.
The bad:
Needs new top (current one is functional, but ugly)
Hood has dent in front.
Front bumper has some scrapes
Whole car has a few dings and scratches
No A/C installed
No front sway bar.
Rattles on bumps.
Stock rear (seems to be in great shape, but wouldn't push it too hard with this kind of power)
The short block alone would cost someone $3500 or better. Throw in $1000 for a set of heads, $1100 for a Fast 90/90 and your up to $5600 for just the basic long block and intake. Nitrous kit would very easily sell for $500 (with everything I've got with it) and the Hptuners Suite + Jotto desk mount would go for around $400 as well. The list goes on and on.
I beleive this is an awsome deal for someone (maybe just because I've sunk so much money in it)
Constructive criticism on this sale is welcome. I don't know what something like this should bring. Please don't get on here and bash away though.
Danny
469-853-4867
Oh yeah, and this car is fast!! Like I said, haven't gotten to play with new motor yet, but I would almost guarantee it will go 110mph in the 1/8 on the 150 shot (motor could handle 300 shot I bet). I'm sure around 98mph+ on motor.
Throw a rear under it and go low 10's maybe high 9's in the 1/4. Maybe faster, people on here could tell ya.
I also have a Ford 9" w/ 4.11s and detroit locker that could be negotiated as well. Was gonna put it in as soon as I found a housing.
Forged 383
White w/ white top
$8500
GENERAL
TRANSMISSION
Drill Mod
2001 Slave Cylinder
Fast 90 Intake
LG lid
ENGINE
Compression 12:1
LS7 roller lifters
ARP head bolts
ARP main studs
New water pump
NITROUS KIT
TNT Purge kit
TNT bottle heater
FLUIDS
MISC
Stuff Removed
!EGR/AIR
!Front sway bar
!CAGS
The bad:
No A/C installed
No front sway bar.
Rattles on bumps.
Danny
469-853-4867
