F/S - LT1 LE1 Heads and Cam
Hey guys I don't post here much, but I have a LE1 setup that I took out of my Camaro a couple months ago. I don't have the flow sheet for the heads but they flow around 25x cfm and have upgraded SI 2.02/1.60 valves. The cam is 22x/23x .56x/.55x 110LSA. This set up made 397/376 for me and has around 15K miles. I'm asking $850 for the heads and $200 for the cam. Here are my dyno sheet and pics.
I also have a BBK 52mm TB $175
He is a good guy. His car sounded good with this set up.
Here is some info about the heads from elliots website.
The LT1 LE1 heads consist of:
Stock Valves with Back Out
Crane 10308-1 dbl valve spring, retainer and lock kit
195 CC Intake Port
Milling, Cleaning, Assembly
Flow About 260/180
Ready to bolt on
195 CC Intake Port
Flow About 260/180
Ready to bolt on
Thanks irbs, I totally forgot to mention that I upgraded the valves to SI valves that are 2.02/1.60 I'll edit the first post. Also like irbs mentioned it sounded mean. Here is a clip.
Click here to see Video
I just might have to take the cam from you, but I have to know.....car looks like a 1997, interior, tail lights, and guages, but NOT digital odometer? I thought all 97s had digital odo? Is yours a really early version of a 97?
