eibach pro kit and other goodies - installed
alright guys, after much pain and suffering, scott and i finally finished installing my parts at about 4:00 this morning. we didn't get the torque arm in, but other than that the only things left out were the SFC's and gear, because i need to pretty much have a shop install them.
BEFORE:
AFTER:
THE BAD:
so yeah, i guess you really do have to roll your fenders
i think i also need to adjust on the PHB a little more. we eyeballed it last night and it looks pretty damn perfect, but it only rubs on the left side, so i guess it's not as perfect as it may seem. i also did a search here, and it appears KYB shocks are cheap for a reason :iono:. i'm going to try to get everything adjusted out to where it's driveable for now, and i'll probably just have to pony up for a set of revalved bilsteins from strano or something.
BEFORE:
AFTER:
THE BAD:
i don't know if it's just the 11" rims that will rub. mine definitely rub, but i like i said i have some adjusting to do on the PHB
the stance is nicer but eibach springs are too bouncy for me, you should roll your frenders but your rear tires should only rub when you have more than 2 people in the car. Other than that if its rubbing, id go with something different.
i got those airbags that you can buy from jegs and put them inside the spring and inflated them just enough to prevent the suspension from going that low and avoid ruining the tire, im running 20's right now put the bags in and did not inflate them and no problems with the hotchis kit, but when i had my stockers it was a problem
thanks joe! hopefully i'll be making another kemah meet sooner or later
