miller syncrowave 180sd- should i buy if i want to get into tig?
hey guys- looking at potentially getting a TIG setup to learn and do some things with aluminum, stainless, etc. I currently have a lincoln weldpack 100 that I've used over the years, but never really happy with. In hindsight, I bought it without research, but it was only 300 new back then.
Looking at some of the used TIG setups, looks like I can pickup one of these Miller 180SD machines for less than 1k. Is that a decent price? Any other recommendations for a tig setup new/used in the 1000-1500 range? thoughts?
I've been doing a lot of shopping for a tig lately, so I'll just relay what I've found.
The 180SD is a decent machine, but some guys "outgrow" them pretty quickly. 1/4" aluminum is really pushing it. It's also heavy, being a transformer based machine. But it's solid. As long as it's under $1k, it's a fair price. The Syncrowave 200 is starting to appear in the low-$1k range these days. No way would I pay more than $1000 for a 180SD. Go in to it as long as you're happy with 3/16" aluminum and below, and you'll be fine.
Brand new you can get the Miller Diversion 165, which is an inverter machine, for ~$1250 shipped to your door from any number of internet vendors. Controls on it are pretty basic, but the people that have them seem to like them. It's got about the same capacity as the 180SD, but weighs less and consumes less power. Transformer machines require more current (I'd bet 40-50A for the 180SD), inverter machines are much more efficient (23 amps for the Diversion).
Skip the Econotig. Rarely see love for those machines, there's a reason a lot of them are for sale. Heavy and underpowered (from what I've read).
You could go Chinese - I almost bought an Everlast 250EX (would have, if it were in stock). It's got a lot of nice features. http://www.everlastgenerators.com
I ended up buying an HTP Invertig 201. It'll be here tomorrow. Very nice looking machine, and HTP seems to be a great company to buy from. http://www.usaweld.com
The 180 is a little bit underpowerd for what it consumes, and is a transformer machine.
I like both, but after I bought my dynasty I havent turned on my syncrowave 250 even once. The arc is simply amazing on an inverter, plain and simple. And on the dynasty, it is so adjustable on aluminum its not even funny.... The diversion isnt, but it still has a nice arc.
Basically, I like the diversion over the 180...
If a person wants to do it right, the dynasty 200 is an amazing machine for it size and would run circles around the syncrowave 180 and 200. Even the dynasty 200 sd with out the pulse controls is better.
The diversion seems to be a little limited in its torch and could be expensive to replace. I am not a fan of roller switches, though on aluminum are useful. The switch is built into the torch.
Another decent place is www.cyberweld.com .This is where I purchased my Miller 211. No complaints, fast and free shipping as well.
i have a miller 180 sd for a few years now and i like it alot....but i have never used a dynasty.....my miller has always done about anything i wanted it too...but if you get it i would highly suggest getting a water cooled torch setup for it.....i made my own with making a stainless water tank,a sump pump,and a used torch from a friend.....works great...
I have a 180 SD. I like it and have never had any issues with it. I doubt there is much automotive welding you couldn't do with it. If you really needed to tig 1/4 inch aluminun, you can run 100% Helium to get it a bit hotter. Of course, if you have the means, go for the Dynasty. Otherwise spend 1G on the used 180 and get a good mig for the money you saved.
Ryph
Ryph
I don't know everything that you'll be welding but If I were you I'd look into buying a used Syncro 250 or larger or equivalent Lincoln , L Tec , or Esab . I know a bigger machine can have some serious amp draw but you're not going to run the compressor & weld @ the same time . I've seen some nice setups with a cooler for 1200 . The bigger TIG machines usually come with pulse , you won't need a sequencer but AC balance is nice . Later on if you want to sell it you should recoup most of the cost . What will the 180SD be worth in a year ? Most people end up wanting more power not many want less . It'll be heavy so put it on wheels . The Dynasty is awesome , we have 2 350's and they're just bad *** . The AC side can be focused so well you have to see it .
FWIW, I've been welding with my Invertig since last week, and I'm loving it. Tig is great. So clean. It's a lot slower than my mig, but the process and results are much cleaner.
I've never tig'd before, took me a few evenings to get the hang of it, but now I'm up and running.
I don't know everything that you'll be welding but If I were you I'd look into buying a used Syncro 250 or larger or equivalent Lincoln , L Tec , or Esab . I know a bigger machine can have some serious amp draw but you're not going to run the compressor & weld @ the same time ..
I still prefer the industrial machines , they have better low end as well . I know they're a bit much in a garage setting but a Syncro 250 isn't much bigger or heavier than a 180SD or Syncro 200 . I'm always trying to maximize my buys , and if I get a lot more for a little more money I've done well . An inverter machine would be perfect for you but they're expensive . Have you atleast gone and tried to lay down some beads ? Get a little experience so when you go to look @ a machine you understand what you're looking for and what your looking @ and if it'll suit your needs . If it were my dime , I'd be looking for a used Syncro 250 or Lincoln Precision TIG 250 . Then if you decide you want more or don't want it you'll get most of your money back . You'll want a cooler but if it doesn't have one they're easy to make .
I have the 180SD and love it, plus you can stick weld with it, so that's one less piece of equipment in your way. Try doing that with your Miller Diversion 165. Plus the Miller Diversion 165, has half the duty cycle of a 180SD, as would most non-transformer based welders. You have to give up something to gain something else. One of my buddies has the Miller Diversion 165 and loves it, so its all in what you plans are.
The other thing to remember is the bigger the machine, the bigger the torch, so if you over buy on the machine size, it will not let you get in those tight corners on the smaller jobs
The upper end dynasty's 200, 350, old 300, 700, all have better duty cycles then their transformer based counterparts, they are more efficient, and draw alot less power.... diversion is the exception.
the more i read and research, the more it seems a 250 type machine is the right investment for long term needs/ flexibility. that obviously blows my budget of $1500 now, which for a hobby (not a living) is really too much cash... Do I have any other options, or just bite the bullet and get one :-)
