Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
DIY Ramps how to
Old 07-22-2012, 03:46 PM
charchri4's Avatar
Default DIY Ramps how to
My ramps are awesome DIY ramps and if you have a lowered car with wide tires these are a must have especially to do alignments.
The tops of the bases are 11" wide by 20" long and raise the car 9". The bottom part of them are 11" wide by 24" long. Mine are nearly all wood I had lying around and you can do the math to figure out that is a lot of feet of 2x4s!
The risers or actual ramp part is 54" long and the tops of them are 2x10s. The reason for the little hunk of 2x6 at the top is because a 10 foot 2x10 was quiet a bit cheaper then a 12" 2x10 so I just added on to it. The boards under the deck are 2x4s laid on their side. Using them alone raises the car 5".
Everything is screwed together with LOTS of 2 1/2" sheet rock screws.
They are very stable and I feel really comfortable under them. If you want to add a safety feature you could put a little tab down on the riser to lock it into the base. Or you could go up from the base into the riser. I was planning on doing that but never did. I've used these for years and never had one move.
The dents you see in the top of them are from using them as jack stands. Often when I have it up on the ramps and pull a wheel I just kick the ramp under the car and set it on it. It's the perfect height to sit right on the jacking point of the car or under the K member. I should patient these puppies!
By the way the trick to getting the risers cut exactly right is put the tops up on a 2x4 and scribe a line on your riser boards like so:
For little stuff or oil changes I use just the riser part which is the main reason I never put the tab in them that would lock them to the deck.
__________________________________________________ __________________________________________________ ___
Update 2014
I built a set of rear ramps to deal with the ISD in my Miata.
Yeap those are new 2x4s I had to buy them this time!
They are the same 11" wide and 20" long as the tops of the front ramps.
They are one layer higher than the fronts so I made a spacer I set on the fronts when I use them.
That does shorten the tops of the front a little which is not ideal but works. The reason I made the backs one layer higher is I knew I would never drive up on them so I made them as high as my jack would go.
Old 07-22-2012, 06:11 PM
2nasty's Avatar
What are those 2 chunks of wood on the back side of the risers for support? Measurements please? And would you make them longer?
Also whats the measurement of the piece that sits under the risers on the base?
Old 07-22-2012, 08:02 PM
bad_408_vert's Avatar
sorry to be off topic , but, are your fog lights stock?
Old 07-22-2012, 08:03 PM
got milk??'s Avatar
Looking good, paint them and I bet they last forever!
Old 07-22-2012, 08:13 PM
Conrad's Avatar
These are cool, saw them in another thread of yours. I will probably make something like this. Do you think the ramps could be steeper without being longer? I would want more of a lift.
Old 07-22-2012, 09:00 PM
98camarols1's Avatar
i just builded me set today..used some of your idea.lol
Old 07-26-2012, 04:29 PM
charchri4's Avatar
I put those little 2x2s in there about a year after I made the ramps for a little extra lateral support. Mostly for when I am just using the risers as ramps. You wouldn't really need them if you put enough screws in the top.
No I wouldn't make them any longer. They are plenty long and a nice gradual incline to put the car up on.
Old 07-26-2012, 08:12 PM
charchri4's Avatar
Yeah I think you could go up one more level with the same length easy. That would give you 10.5" of lift but I have never thought it necessary except once. When I put my headers in I had the car up on the ramps then jacked it up another 4.5" from there with blocks on the ramps. For the last 3 Camaros and last half dozen years these have worked fine at 9"
Old 07-26-2012, 08:15 PM
charchri4's Avatar
The little lights on the outside are stock. I think they are part of the SS package? If you are talking about the 2 shiny things right in the center by the license plate those are brake duct inlets not lights.
https://ls1tech.com/forums/suspensio...l#post16605601
Old 07-29-2012, 07:32 PM
Doug G's Avatar
Nice build... only thing I'd add is better lateral support than only those 2 little blocks on the ramps.
Old 08-03-2012, 12:22 PM
ghettocruiser's Avatar
I like this design! Mine are 2x10s sandwiched on top of each other getting shorter and shorter as you go up. Then I also built a stand of all 2x10 to use if I need to go in under the side or get the trans out.
BUT...mine are EXTREMELY heavy. After a day of working, they are a bear to move around or store. Yours not only look lighter, but being two pieces would make them easier to stash too.
I might re-vamp my ramps and go with this idea. Been wanting to make a new set that are more user friendly. Plus I can steal some 2x10s from my ramps, and 2x4s are cheap enough.
Thanks!
J.
Old 08-03-2012, 01:04 PM
zacht's Avatar
Thanks!
J.
mine are like this!!! i share your thoughts...they are heavy as hell...
Old 08-08-2012, 04:58 PM
Darth Cypher's Avatar
My Rhino ramps are **** and want something that has a lower angle and is wider. Like what I see here. I might incorporate some of these ideas into my plans. One question I have is what type of wood do you buy from the store? I don't have a saw or anything so I will have to have it cut there and then bring the pieces home to put together.
Old 08-09-2012, 12:13 PM
charchri4's Avatar
They are lighter for sure then planks and easier to store in pieces but the best thing is being able to get rid of that riser for easy access.
Old 08-09-2012, 12:30 PM
charchri4's Avatar
All of what you see there I had lying around except the riser tops. The only reason they are 11" wide is because I had a pile of 2x4s that were cut to 90" and I could get 8 cross bars out of each one.
If think I was going to start from scratch I would probably use a 2x6 on edge for the center 2 layers rather then so many layers of 2x4s. But to answer your question this is all just basic framing lumber that any lumber yard could cut down for you. Just draw out what you want to do on paper and figure out how many of each length you will need. The lumber yard in my little town (pop. 1200) doesn't charge for cuts but I bet places like home depot does so you better watch that.
The other thing you might do is go talk to your local high school wood shop teacher. If he is like the one in my town he is always looking for easy projects like this and you would might be able to get these made for the cost of the wood.
Good luck!
Old 08-10-2012, 03:29 AM
VETTEX2's Avatar
Rhino's are only 40 bucks and they are lighter
Old 08-10-2012, 06:49 AM
charchri4's Avatar
Originally Posted by VETTEX2
Rhino's are onlym 40 bucks and they are lighter
Sure I really enjoy piling up the shims to get lower cars on and working around the risers that are totally in the way to do anything like SFCs or a clutch. I wouldn't trade you if mine cost twice that.
Old 08-16-2012, 03:25 PM
leon phelps's Avatar
nice post. Fred and Lamont would be proud.
Old 08-17-2012, 10:38 AM
btlegacy's Avatar
That is very ingenious. Nice job!
Old 08-23-2012, 03:15 AM
VETTEX2's Avatar
My car is lowered and rolls right up.
I use my lift for big jobs , you out'a try one
I wouldn't trade any tools I own , ever.
Of course i don't go for ghetto solutions.
Quick Reply: DIY Ramps how to
