Every Tech should have this LS Timing cover Alignment Tool!
Sorry I missed your post. Did you receive the tool? Not sure what happened.
Thank you for your business!
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Hi Blown06,
Sorry your order took more than a week to get. Not sure what happened.
I know at one time we had a small back order
but generally everyone got theirs within 5-6 days.
We now ship same day on all our AlignIts tool orders.
Thank you,
Christian
Thank you,
Christian
__________________
Same day shipping!
__________________
I just put a order in for the timing cover, oil pump, and rear cover tool. Looking forward to trying them out. After I am done I will pass them along to my brother and he will get to try them out on his motor swap.
Christian
__________________
Christian
__________________
#32
I used the oil pump, front cover, and rear cover align it tools when I built my 402 and I have to say they are amazing! They are easy to use and make the process a lot easier. Not to mention they are a hell of a lot cheaper then the actual kent-moore tools.
#34
We are not selling the OP tool because you should always pull the pump cover and double check the clearances anyway just in case there is a flaw in the factory machine work on the pump. Since you should pull the cover and check the clearance anyway demand for the tool was low and not worth manufacturing more of them.
Thanks
Christian
__________________
