What Impact gun for removing crank bolts?
Getting really tired of the cheater pipe method lol. I do have a cheap Craftsman 1/2 inch impact driver but that thing has trouble getting my wheels off at times
The compressor I have maxes out at 125psi, Is that also a problem?
Can anyone recommend a good impact gun?
I use a matco mt1769 it's pricey but works awesome. Over 1100 ftlb of breakaway torque. The psi of your air compressor isn't important. Most air tools use 90psi the cfm is the important number usually the better quality of tool the less cfm required to use it.
8 Second Truck Club
The cfm rating of the compressor is used to determine its capacity for continuous use, and likely would have no effect on how good it would run an impact tool as they are not used continuously with the compressor running. The tool has a cfm usage rating at 90 psi which, across brands and tools, isn't a likely measure of how much power the thing generates.
Cranking the psi up on the regulator will have a drastic effect on impact performance.
Harbor Freight has their "Earthquake" series which works really well. For about $80 (plus can use 20% coupon), you can't beat the 1/2 inch impact in my opinion.
If you don't want HF, I suggest IR or Snap On if you want something really nice. Of course you'll pay for it though.
i used a cheap $30 Harbor Freight impact when i took mine off my LH6 5.3 ... had to heat up the bolt head a LITTLE to soften up the sealer on it. used propane and counted to 90. after that the bolt came right out. didnt even use the locking tool to remove or install
hope that helps.
hope that helps.
I would tend to think a breaker bar is sometimes easier to get on the crank bolts.
Given the space allowed most of the time between the motor and radiator etc., a socket and breaker bar takes up far less room than a gun and hose.
If it's not that easy...put an extension on lol.
I have an that I use as much as possible. It should be able to handle correctly installed (non-cross threaded) crank pulley bolts without a problem. However, I always recommend using hand tools to remove a crank pulley bolt to prevent the possibility of the head breaking off and the rest of the bolt being stuck inside of the crank.
8 Second Truck Club
I have an Ingersoll-Rand 2130 that I use as much as possible. It should be able to handle correctly installed (non-cross threaded) crank pulley bolts without a problem. However, I always recommend using hand tools to remove a crank pulley bolt to prevent the possibility of the head breaking off and the rest of the bolt being stuck inside of the crank.
I use an IR-7150. No air needed. I also use 2135QTiMAX. They both work great. Hand is the smartest way, but I am lazy and my joints hate loosening the high torque fasteners.
I don't care what you all are saying. I have a 1500lb impact and there are times when the 4ft gas line pipe/cheater is the only way to go. Pyramids were not built with cranes. They used simple machines. You can feel what the bolt is doing by hand.
Map gas torch and pb blaster over night helps. The 1/2 in air line makes a big difference though. Like a fire hose compared to a garden hose. Which will you use to put out a house fire......
ive been using my craftsman heat gun for over 10 yrs. got I when craftsman still made quality tools. the heat gun gets hot enuff to make metal glow red. im not big on using torches near electric wiring and plastic parts.
use a heat gun. with a breaker bar to remove the bolt. I think my 12 point 24mm 1/2 drive deep socket bites better on the hex head of the stock crank bolts. ive yet to break a stock crank bolt. so far.so good
