Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
egr block off plates blueprint
Old 12-04-2014, 12:53 PM
00birdls1's Avatar
Default egr block off plates blueprint
Hey guys here pretty quick I plan on getting my egr and air pump deleted and was wondering if anyone had the dimensions of the block off plates for both so maybe I can get them made at work and give them a one of a kind look...thanks guys
Old 12-07-2014, 03:38 PM
00birdls1's Avatar
Anyone?
Old 12-08-2014, 03:15 PM
blackbyrd's Avatar
I think there is a gasket in between where they all connect. use the gasket to make a template
Old 12-08-2014, 07:42 PM
00birdls1's Avatar
What about where the egr goes down into the intake? What's the diameter and how deep does the plug need to be to seal it off?
Old 12-09-2014, 09:57 AM
blackbyrd's Avatar
same deal mesaure the gasket and the hole in the center where the egr tube goes through, than just measure the tube down to the o-ring. Or look them up on Ebay and you can buy them pretty cheap
Old 12-09-2014, 12:43 PM
00birdls1's Avatar
I got to planning last night and looking further into it and more then likely I'll make all of them and buy the intake block off
Old 12-09-2014, 01:06 PM
blackbyrd's Avatar
I made the ones for the header section as well. Had some scrap stainless that worked out great. My intake doesnt have the Egr provision so its not something I had to deal with on my motor.
If I did i would probably just buy it off ebay as i dressed my engine up a bit and there are some really nice options out of the ones I saw. Though i did see one option that looked like a bottlecap style freeze plug, might be a cheaper option than the stainless pretty plates if you want to try that out as well.
Good luck!
Old 12-28-2014, 09:23 PM
mrich0908's Avatar
I made a solidworks file and gcode from solidcam a few months ago if you still need the egr deletes. It was made for .125 steel. Thats what I had laying around.
My engines a gen1 5.7 vortec though. The file is for the two air egr bungs off the headers on my long tubes.
Old 01-10-2015, 12:57 AM
00birdls1's Avatar
I ended up using the gaskets as templates to make the bloblock offs on the headers and just bought one for the intake and painted it to match a little better...thanks for the advice
Quick Reply: egr block off plates blueprint
