Tig welder opinions
Tig welder opinions
What do you guys think about this welder?
http://www.harborfreight.com/165-amp...der-61792.html
Yeah, I know it isn't the best quality. I am going to use it to piece together my hot side and maybe do a little more fabrication work. I am having trouble trying to find someone to tig weld it for me. Not alot of fabrication guys here in my neck of the woods in NY. I was going to tack it together. I have called a few machine shops and can't find anyone. I have a nice mig, but I've seen the way most mig welds come out on thin exhaust pipe, and I don't like it. I have never tig'd before, but I would take the time to practice on some scrap. For about $350(with the tank), I would have a small tig. I figure I would send out some feelers to see if anyone used it, or knows someone. If it comes back bad then I will keep looking for someone to weld it up for me, even if I have to travel. I just can't justify a big dollar welder for what I am going to use it for. If anyone has any other options, I am all ears. Thanks in advance.
Restricted User
Longevity Tigweld 200sx.
Offer them 800 on their website and they'll take it. I've welded quarter inch mild steel using the 15a 110v outlet in my garage and this TIG has NEVER skipped a beat. Cannot beat it for the price. Ever.
I have an alphaTig 200x and its awesome. For the price being an inverter style machine that can do DC/AC, tons of options, 110/240v its hard to beat. I got mine from Kevin Caron for like 700.00 shipped.
Sure wouldn't we all like to spend $2500 on a tig. But not all of us can afford it. I have a good friend that had a hf tig welder and it worked pretty well for exhaust and charge pipes that were stainless. It wouldn't do aluminum. But for the price you can't really beat it for the hobbies. Don't expect to make a living off it but the op seems like he just wants to use it from time to time. You can search craigslist for a used tig but even then most are more then $750
One caution I'd give about too cheap of a welder is if you don't fully know how to tig weld & the machine isn't doing it's job properly, it can make attempting to work a frustrating process. This could result in giving up on a skill you could become really good at if given a proper chance.
Also if you do pick up ok on steel welding, you may really want to try aluminum. May really want something at least good enough to do both.
When paying money for tools, always consider if paying a little more now will pay for itself later on in the future of your lifetime .
I understand low budget & trying to save money as well as anyone, but it is too easy to screw yourself trying to use an inadequate too for some jobs. For example, if you have a broken off bolt with just enough to grab with vice grips & a prayer, would you use a$2.00 harbor freight pair or pay more like $15 for a real pair.
Just something to consider.
Another overlooked option for low buck steel welding is an old school torch setup. Takes no electricity, so you can do anywhere. and cut steel if needed. Gas is expensive these days though. But they are still good for certain projects, small aluminum projects also. The henrob/cobra heads can do some precise work for some projects. Something Just to keep in mind if you come across one for super cheap.
One caution I'd give about too cheap of a welder is if you don't fully know how to tig weld & the machine isn't doing it's job properly, it can make attempting to work a frustrating process. This could result in giving up on a skill you could become really good at if given a proper chance. Also if you do pick up ok on steel welding, you may really want to try aluminum. May really want something at least good enough to do both. When paying money for tools, always consider if paying a little more now will pay for itself later on in the future of your lifetime . I understand low budget & trying to save money as well as anyone, but it is too easy to screw yourself trying to use an inadequate too for some jobs. For example, if you have a broken off bolt with just enough to grab with vice grips & a prayer, would you use a$2.00 harbor freight pair or pay more like $15 for a real pair. Just something to consider. Another overlooked option for low buck steel welding is an old school torch setup. Takes no electricity, so you can do anywhere. and cut steel if needed. Gas is expensive these days though. But they are still good for certain projects, small aluminum projects also. The henrob/cobra heads can do some precise work for some projects. Something Just to keep in mind if you come across one for super cheap.
it's called a torch. and no one mentioned duct tape.
http://weldwarehouse.com/cgi-bin/ein...66=WP-26V-12-R
this type of set up is really common in pipelining and ship building. it's cheap and robust.
having the nicest equipment does not result in the nicest weld. practice does.
"the welder does not make the weldor"
it's called a torch. and no one mentioned duct tape. http://weldwarehouse.com/cgi-bin/ein...66=WP-26V-12-R this type of set up is really common in pipelining and ship building. it's cheap and robust. having the nicest equipment does not result in the nicest weld. practice does. "the welder does not make the weldor"
IMO
AHP sells a nice TIG welder based upon the reviews I have seen. It is very similar to the Longevity TIG I have had for 4 years. They are sold at Lowes and Amazon and tons of other retailers. For $750 they are a pretty good deal. The whole plasma/TIG quality debacle around 2008 issues have been resolved. Quality has greatly improved on the Chinese welders.
Here is a discussion of real world users of the Chinese TIG welders.
http://weldingweb.com/showthread.php...e-used-own-one!
Ive been using an Everlast PowerPro 256 TIG/Plasma/Stick I bought in 2010 and so far have made about 20 thin wall aluminum intake manifolds with it. I am very happy with it and it was only about $1700. Its had two breakdowns, both from the same thing, a certain chip blows and you need to swap it out to fix it. Costs about $5. Totally worth it in my opinion and only takes a few minutes. Has happened twice in 4 years. Im not sure if they've fixed it in their latest design but even if they havent I would still recommend the welder.
I weld up the intakes as fast as I can so I dont spend alot of time making perfect stack of dimes, but you certainly could if that was the desire.
ive got the thermal arc 95s. its an inverter scratch start tig setup. you can purchase it for under 500 bucks and it will arc weld too. the only problem is that you are limited to 95 amps. for what I use it for though ive never had a problem.ive never used the harbor freight set up so I wont comment on it.in the end its your choice but there are some decently affordable options out there
I'm a boilermaker and weld/fabricate for a living. I weld x-ray code work everyday and I've never done anything else for work. I say that to back up that I know what I'm talking about when it comes to welders. 5 years ago I bought a miller dynasty 200dx for personal use because I got tired of turning people away that wanted me to fix stuff for them and also for my own use. I've paid for the dynasty at least 5 times over easily. You get what you pay for and I'm not saying everyone needs a dynasty as they are complex machines but save yourself the headache of going cheap. It'll only make the learning curve steeper and perhaps impossible.
Dynasty 200DX here. Maybe 1 hr tops useage. Now it sits. LOL
