torque wrench for use in tight spaces?- header bolts
I need a 6torque wrench that can be used in tight spaces. Thoughts? In the past, I never used a wrench, but I am sure that there must be one out there for these situations.
I wouldn't bother trying to use a torque wrench. With the right gaskets and locking header bolts (I run Stage 8 brand) you shouldn't have a problem. Just grasp your ratchet at the same basic position on the handle when tightening each one (i.e. on my 10.5" long 3/8" ratchet, I wouldn't be totally at the end) and tighten everything fairly equally. You'll be fine.
