Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Oil pump center sprocket removal tool??
Old 03-10-2005, 08:25 PM
soundengineer's Avatar
Default Oil pump center sprocket removal tool??
the cam sprocket on the engine that the oil pump sits on...
whats the best tol for removing it....???
I remember it being a pin in the *** on my last car/cam
and I am gathering up stuff to do a change on this new one...and I remembered that being a bitch!!
almost forgot to say why its gotta come off.... putting on a double chain...need to remove it to put on the lower chain sprocket...
Old 03-15-2005, 10:31 AM
robertbartsch's Avatar
I think I used a standard 2-arm gear puller on mine....
Ask this question in the internal engine sections since you will get more traffic on this topic...
Old 04-11-2005, 06:54 PM
Zinc's Avatar
Just pulled mine off 30mins ago. Used a 4" 2 armed gear puller.
Old 04-12-2005, 06:27 AM
1BADAIR's Avatar
I used a 5 ton 3 jaw puller that the arms were ground down on a bit.
Old 04-12-2005, 11:31 AM
Camaro_Zach's Avatar
plasma cutter
haha
