Where to get 10+ gals of solvent / Parts wash
My wife just bought me a 20 gallon parts wash from Harbor Freight.
Does anyone know where to get 10 or more gallons of solvent or WD-40 cheap? I'm think two 5 gallon buckets. I filled it with 10 gallons of water and it worked great and stayed at a high enough level.
Buying in indiviudual 1 gal containers gets real expensive real quick. I'd like to keep the cost down around $50-$75 if possible.
THanks,
David
THanks,
David
This is the largest WD-40 I found... at a UK site unfortunately http://www.tooled-up.com/Product.asp?PID=90421
Ebay might have something too, worth a look.
Originally Posted by ROCNDAV
Does it evaporate like Acetone or brake cleaner? Do you know where I can buy it in large quantities?
Does anyone know where to get 10 or more gallons of solvent or WD-40 cheap? Thanks, David
Originally Posted by gto69judge
The Advance Auto Store near me carries it in 5 gallon cans. Did you check with Pep Boys, Murray's, Autozone stores etc. near you?
Originally Posted by Predator
Yup, I got 10 gallons (2) 5 gallon drums at Advance Auto Parts called "Next Dimension Parts Cleaner," but it isn't cheap. I forgot if it was $19.95 or $29.95 for five gallons.
There is no Advanced Auto around me in LA. THe closest being in Calexico (border of California & Mexico).
I tried calling all of the Kragens around the LA area, and none of them have Oil Eater any more, nor can they order it , They do have Simple Green in teh 5 gallon size for $38. so I might check into that, but I wouldnt think Water based cleaners/solvents would work good.
Thanks everyone,
David
I wouldn't use a water-based solvent in a parts cleaner either.
I would try calling all the auto parts stores in your area. Maybe just go through the phone book. If that fails, you could probably order that stuff somewhere online.
I'll see what I can find online and get back to you.
Thats not that bad. When you start adding up 1 gallon sizes of products, it quickly gets over $120 for 10 gallons
Thanks everyone,
David
Thanks everyone,
David
Fastenal has alot of the things you are looking for. Branches all over the nation....www.fastenal.com
Jeff
Originally Posted by 777
simple green also corrodes aluminum too i think
Originally Posted by robertbartsch
Using kerosean sounds like a fire hazard... **** ..why not use high test gas
Kerosene works quit well as a solvent for cleaning. It smells much better than diesel fuel and is probably safer.
