welding stainless
welding stainless
I got a new lincoln 135 with gas attachments. I want to MIG weld some 16 gauge stainless tubing. I cant seem to find the setting to use to weld with .030 stainless wire. Anyone have any tips? Arc settings are A B C D and speed setting are 1 -10. Thanks
Aint gonna happen to get a good weld. That welder doesnt create enough heat to heat the base metal hot enough. Aluminum and stainless you have to either TIG or preheat with a torch to about 200° to MIG.
If you want to give it a shot use one step hotter than 16 guage for mild. It just aint gonna make a pretty or strong weld.
It will work but if you do it it isnt real pretty. If it isnt "load bearing" or under a lot of stress the welds will be fine just dont grind them down because you will see that you get VERY little penetration on the weld.
You can try, worst case you are out a little bit of stainless tubing.
I've welded stainless 16 ga tubing a bunch with my craftsman 120amp MIG. Works just fine. Doesn't work any different than mild steel IMO, just not very good overhead. What gas are you using? I use regular 75/25, same for mild steel. There are also 2 different stainless alloy's. I wanna say mine is 316.
Adkoonerstrator
I've wanted to try this Self Shielded Flux Core Stainless Steel wire with my little flux core machine but, don't have anything stainless that I need to weld.
I didn't even know anything like this was made and found this place with a google search. It's the only place I've seen with this wire. There are flux core wires for just about all stainless alloys at the link below.
Someone try it out and let us all know.
http://www.dynamictechnologies.net/ssfc.htm
Is it better to use 100% Argon or a CO2/ Argon blend for stainless?
Ive welded stainless with both mild steel wire, and stainless wire on a MIG. Ive always used whats called Argoshield light here. I think its like 95% Argon, with 5% something else.
Never had any problems. Obviously if you weld the mild steel wire, it will rust a bit. Fairly easy to do though. Its no different that welding mild steel.
Adkoonerstrator
Originally Posted by greentahoe
I would be willing to try it when I redo my exhaust, but Ive seen the difference between flux cored and MIG gas welds and Im going with the gas shielded MIG welds for my FMIC piping since its going to be the first thing you see in the engine bay.
I've welded quite a bit(mild) with flux core wire and besides a little extra cleanup around the weld area I don't see any visual problems with the welds. It's nice not to have to worry about gas.
Cant do any practicing for another week or two as Im in the middle of moving to a new house and then my girl's family are coming down to repaint the already nice looking walls.
Adkoonerstrator
The stainless Im working with is 304. They dont have a flux cored wire with that alloy that I saw. Would the flux cored be as easy to work with or easier (as opposed to gas)? Ive heard it is harder to see the puddle when you use flux cored wire. Im all for it if it will make it easier.
For 304 Stainless I think you need a 308 filler material and they do have some of those alloys in the flux core wire. It'd probably be best to call them to see what they recommend.
If you got gas already though it'd probably be easier to just use it and a non flux core wire.
About seeing the bead, I've never noticed any problem seeing it with flux core. I haven't welded with regular gas wire though so I can't compare.
Steve
If you weld stainless with a mild steel wire thou the mild steel will rust away eventually. Stailess is an agressive metal that eats the metal that surounds it. Its call dissimular metal corrosion. Just something else you should think about. What are you trying to weld thats made of stainless?
1 Post
I don't have a gas setup for my home wire welder, so I can only use flux core. I haven't had any issues with it other than spatter. I can see the puddle just fine, not taking into account my old-man eyes...
Get some extra pipe for practice if you can. Try different speeds/temps. Hold your gun a little closer or a little farther. There's no substitue for time on the gun. We can tell you a lot, but practice helps immensely. Start hot or start cold and work the other way on your settings until you get it right.
I wouldn't think you'd have to have EXACTLY the same SS filler as SS base material. It won't blow up or disintegrate before your eyes. Something close would likely do. You MAY have some issues with cracking, but I'd have to defer to somebody who has gone through this on their car.
If you used mild steel wire, yes, you'd get rust. That would negate some of the maintenance-free aspects of your installation, but it would a good combat fix.
Dunno...your call.
Dunno...your call.
Adkoonerstrator
Originally Posted by Muffracing
I'd really like to know if any of thse flux cored wires work. I work in a welding supply store and the only flux core stainless I know of still need a shilding gas.
