Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
What to put down on the garage floor help.
Old 05-31-2005, 07:00 PM
waterbug1999's Avatar
Default What to put down on the garage floor help.
Did a search and found mostly tile. Which, I dont want and it's expensive. Want something I can paint on, that will hold up and not come off, and not be like an ice rink when it gets a littel wet. Anyone know what works good from experience? Thanks.
Old 05-31-2005, 08:09 PM
moyam01's Avatar
Expoxy with a polyurthane clear coat. It is easy to clean, will last you a while, and if you do it with those little bumps (someone should know what I am talking about) it will help alot with it bing slippery. They use it at my school. But you have to make sure that no moisture is coming through the floor, because it will lift the paint.
Old 05-31-2005, 08:23 PM
How about this crap?
http://www.visiongarageflooring.com/default.htm
Wonder how much it is? Tried calling but answer machine. Guess they were closed.
Quick Reply: What to put down on the garage floor help.
