Not sure what tool this requires? (backseat question)
So I was trying to remove the backseat in my Camaro and realized I needed a 13mm socket wrench. I finally got one and unbolted the backseat. However, now I need to get the seatbelt off and the bolt holding it on has a screw that needs 6 teeth (I suppose that's what you call them). Do you know what this is? I normal screw driver doesn't stay in very well and has yielded little results. Thanks!
Ok, I figured out it's an allen wrench (with the help form my dad). I feel kinda stupid but that's ok. Now the problem is actually getting the bolt off. It's in there tighter than anything else I have tried to take off. Any tricks?
I assume what your are refering to is a TORX head. You can pick up a cheap set at your local autoparts store for very little money. They go on a 3/8 ratchet. I would recommend just getting the right tool, not trying to get it out with the wrong one.... Good luck.
i used a big screwdriver that wedged into the slots tight.....if you strip it out you can always use channel locks or vise grips....
or you can buy a torx driver....i hate those stupid things
