Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Anyone have this tool...
Old 10-31-2005, 12:07 AM
nascar20's Avatar
Default Anyone have this tool...
Last year, when I installed my Lecarra steering wheel, I accidentally broke the small sleeve that houses the wire for the horn on the "turn signal cancel cam" . In order to get this part out of my steering column to replace it, I need to remove the "shaft lock plate" via a "lock plate compressor" p/n J 23653-SIR. I have already emailed SPX to see if they carry the tool, but I'd hate to buy it just for this one job. If any of you guys out there either have this tool or have and idea of using some other kind to tool give me a shout. If you're close enough to NY, I will come out if you'll lend me it. Thanks!
Old 10-31-2005, 12:18 AM
nascar20's Avatar
BTW, In case you are wondering how the steering wheel looks, check below...
Old 10-31-2005, 11:26 PM
ACW
ACW's Avatar
Here's a thread that discusses some possible workarounds for needing the tool (not sure if they'd help in your case or not): http://www.c5forum.com/cgi-bin/ultim...ic/1/3449.html
And here's a place you can order one online if need be: http://www.toolsource.com/ost/produc...00&pf_id=61403
Old 10-31-2005, 11:35 PM
Cody Brooks's Avatar
go to sears or nearly any tool or parts store and pick one up for like $10.
