Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
which jack to use for lowered car?
Old 11-11-2005, 10:17 AM
tranzam01's Avatar
Default which jack to use for lowered car
ok now that my TA is lowered I can,t use my exsiting Jack. What jack are you using so I can go out and by one?
Old 11-11-2005, 11:07 AM
BigDaddyBry's Avatar
Aluminum racing jack at autozone is an option for around $80.
If you have SFCs and rhino ramps, you can still get it off all 4s relatively easy by backing onto the ramps, using your existing jack and jacking up by the SFCs. Not pretty, takes a little more time, but it works for me.
Old 11-11-2005, 12:27 PM
ls1mongrel's Avatar
I got a craftsman low profile aluminum that fit under my buddies lowered z28 ! Its about 150 bucks, but its nice !
Old 11-11-2005, 12:57 PM
iamsickofitall's Avatar
your existing jack may do you fine...try driving up onto a couple of 2x4's to get you off the ground - 10 bux on wood is alot easier than buying a new jack
Old 11-11-2005, 02:19 PM
tranzam01's Avatar
thanks for the info fellas..........
iamsickofitall i never thought about that ....i'll give that a try
Old 11-11-2005, 03:13 PM
Moderator
davered00ss's Avatar
Craftsman Aluminum and/or stock car jack from your car.
Old 11-11-2005, 03:59 PM
rdeterman's Avatar
i have the same one.. its perfect for the car!
Old 11-11-2005, 04:03 PM
Moderator
If you get the Aluminum/Steel version, it is $80. same jack Just steel & aluminum.
Old 11-12-2005, 01:45 AM
MdFormula350's Avatar
the craftsman 1.5 ton alum. one the handle doesnt go down far enough to fit under my front nose. the big heavy steel craftsman one i have fits under their fine.
Old 11-12-2005, 11:54 AM
SSU's Drunk Typing Whore
Lithium's Avatar
Another vote for Rhino ramps. Have them, love them, cheap as hell.
What up? how you doing?
Old 11-12-2005, 12:08 PM
DreamState23x's Avatar
This is what I have too. Got it at sears I think I paid 120, I love it.
Old 11-12-2005, 12:47 PM
Moderator
I have to use one on each side and lift the front that way. The air dam gets in the way.
Moderator
Also Rhino ramps work great.
Old 11-12-2005, 01:09 PM
tranzam01's Avatar
wuts up lithuim .......I was out of town for a week visting the family. other than that i plan on doing my brake job next week. u been busy with school and work?
Old 11-12-2005, 01:13 PM
Lithium's Avatar
Yeah way to busy...if you need any help with the swap I would more than glad to help you out. Let me know.
Old 11-15-2005, 01:16 PM
Ackattack1's Avatar
I have rhino ramps, but I have to use a piece of wood as an extension to get on them without them hitting the body first.
Old 11-20-2005, 12:42 PM
santiago's Avatar
my car sits about 3 inches off the ground and I have one of those 2 ton jacks.
so what i do is i cut up 4 peices of 2x4 about 2foot long put them in front of all of my tirres then drive up onto them. after that the 2 ton jack fits under there nicely and saved me the money of buying a lowprofile jack.
good luck
Old 11-20-2005, 03:44 PM
Brandon Boomhauer's Avatar
the problem with the heavy multi pump craftsmen jacks (IMO) is they dont like very short pumps, where as a quick pump alum jack will move the saddle with 1" of travel on the handle. Sams Club, and other stores like that usually have a good deal on the light weight alum jacks. Ebay too.
Old 11-20-2005, 03:54 PM
JustAnIlluzion's Avatar
i have a floor jack from harbor freight, its big and cost 44 bucks. the aluminum is 70 and a bit smaller but i dont mind hauling this heavy sucker around the shop.
Quick Reply: which jack to use for lowered car?
