Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
best tool to fill cylinder with air?
Old 11-16-2005, 10:34 PM
BlkSS1755's Avatar
Default best tool to fill cylinder with air?
i'm doing valve springs on my LS1 Vette soon.. can't seem to find the hose and fitting to put air in the cylinders while i'm doing the swap.. can someone point me in the right direction?
thanks in advance
Old 11-17-2005, 06:52 AM
Brains's Avatar
Yeah, any compression test kit should have the right fitting. You can also use a spark plug anti-fouler, and adapt to your air hose.
Old 11-18-2005, 09:29 PM
VETTEX2's Avatar
a leak down tester would be my first choice
Old 11-18-2005, 10:06 PM
J&J Speed Shop's Avatar
Lisle Tools available at NAPA or Carquest would have this hose for cheap, or you could find a local tools guy (MAC, Snap On, Matco) and pay more money
Old 11-19-2005, 07:31 AM
JRick212's Avatar
picked mine up at napa but I didn't even end up using them. It was just as easy and safer in my opinion to turn the engine over one at a time putting the cylinders at the top
Old 12-02-2005, 05:08 PM
Zeus's Avatar
Why is that? So in case something breaks the seal you don't have to play fish for the valve stem? J/W because I'm going to be doing a cam swap coming up in a little bit.
FWIW, I went to Vic Hubbards which is a one-off speed shop where I'm from and they had a hose specially made for the job, it was only $11.
Old 12-02-2005, 05:39 PM
Ωmega's Avatar
I use Tim's tool. Works like a charm
https://ls1tech.com/forums/showpost....8&postcount=86
It's $24 without the spring compressor, which is also good.
Quick Reply: best tool to fill cylinder with air?
