Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
dial torque wrench
Old 04-08-2006, 12:54 AM
SLP4CamaroSS's Avatar
Default dial torque wrench
where can i get a dial torque wrench a cheap one i need one so i can redo my rearend
Old 04-08-2006, 01:09 AM
iroc-z's Avatar
try sears
Old 04-08-2006, 01:34 AM
dont have them there i use to work there
Old 04-08-2006, 01:52 AM
benny92's Avatar
Are you looking for an inch/lb. tq wrench to set the bearings? I found a beam-type for ~$50 from KD-Tools, #2955 0-60in/lb, when I rebuilt my rearend.
Old 04-08-2006, 07:22 PM
is the beam type ok i htought u had to use a dial one
Old 04-08-2006, 09:05 PM
...with cheese.
Armageddon's Avatar
I believe he needs a dial type to set pinion bearing preload. If you want one cheap your going to have to order it online. Any retail store is going to rip you a new one. Check harbor freight for a 1/4" dial meter, maybe northern.
Old 04-08-2006, 09:11 PM
...with cheese.
Armageddon's Avatar
Yea, you need a dial type. Your not looking for the click here, it's more like adjusting tire pressure really... except you can't bleed air out if you overfill/torque I use the snap-on type but I got a great deal on mine. Normally they would be really high.
Old 04-08-2006, 09:25 PM
i heard u can use a beam type troque wrench also
Old 04-08-2006, 09:52 PM
...with cheese.
Armageddon's Avatar
anything with a dial gauge
Old 04-08-2006, 11:26 PM
benny92's Avatar
You can use either one, you just need something able to measure the dragging torque. Beam or dial will measure any torque acting on the wrench, i.e. bearing drag.
in/lb torque wrenches aren't in very high demand and the kd-tools beam wrench was the only "budget" one I could find. Everything else I found were "professional" dial wrenches from Snap-on, Mac, etc. for at least several hundred dollars.
Old 04-09-2006, 12:50 PM
sears has one for liek $25
Old 04-19-2006, 09:57 PM
kenp's Avatar
Got mine new on ebay. Good price.
