Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Torque Wrench
Old 05-07-2006, 10:58 PM
2000Hawk's Avatar
Default Torque Wrench
Where can i get a torque wrench that goes as low as 5ft lbs or maybe even 9. I am planning on doing a cam install, my friend is going to lend me one that goes to 150, but i want one that at least goes as low as 5. Or anyone can chime in on what they used during their cam swap. Thanks
-Joel
Old 05-07-2006, 11:27 PM
cbrich's Avatar
I got a torque wrench from Mac tools, it will go down to 30 in-lbs, I am mainly use it for valve bodies on automatic transmission. You might can find one cheaper but you will need one that is very accurate.
Old 05-08-2006, 09:10 AM
2000Hawk's Avatar
Thats the thing when i read LS1howto there were a few things i believe that needed to be tightened down to 9 ft lbs. i believe one of them was the oil pump pick up tube bolt. I know i can do it with a regular wrench, but i want to make sure i don't get carried away and put it to tight. Or even the oil pan bolts, last thing i need would be to have a leak or to break one (knock on wood). Also what 3 armed pulley puller did you guys use to take off the crank pulley?
-Joel
Old 05-09-2006, 07:31 PM
my black ss's Avatar
Default puller
i just bought a standerd 3 bar pully at uh oh zone cost 30 dollars not the real big one the smaller then i put an old bolt in the crank with the edge ground off worked great
Old 05-09-2006, 07:37 PM
'02 SLP#686's Avatar
Inch pound TQ wrench will work for your 9lb - 108in/lb
I snapped off the pickup tube bolt when I asembled my motor the first time
For the puller - most 3 arm pullers will work, put a 3/8 extention in the crank bolt hole - works like a charm
Old 05-10-2006, 06:16 AM
2fast97Z's Avatar
exactly just get an inch pounds and convert it
Old 05-10-2006, 12:10 PM
daryl2cb@yahoo.com's Avatar
http://www.toolsource.com/ost/produc...XCF1BSX5CPFRNA
great cheap puller. used mine 4 times so far, workes great.
Old 05-10-2006, 12:15 PM
best torque wrench I used mine all the time goes down to 5 ft lbs. great for the intake manifold as well
http://www.tooldesk.com/products/pro...l.aspx+id+1630
Old 05-10-2006, 12:24 PM
Just FYI - Torque wrenches are most accurate in the middle of their range. The closer you get to the minimum and maximum the more inaccurate they get.
Old 05-15-2006, 04:06 AM
Silverback's Avatar
FWIW, you don’t want to use a torque wrench anywhere near the bottom of it’s range… they are not accurate down there. Get and in/lb torque wrench for the smaller stuff…
Woops… slp… beat me too it…
Old 05-24-2006, 09:48 PM
WdClaSS99's Avatar
Thumbs up
Snap-on Techwrench - digital torque wrench. Worth it's weight in gold
Old 05-24-2006, 10:50 PM
Those things are slick...
Old 05-25-2006, 01:34 AM
Boostaholic's Avatar
SnapOn for me, have a 3/8's and 1/2 in version - both are great items.
Old 05-25-2006, 02:24 AM
cantdrv65's Avatar
I use a craftsman for the large bolts and my calibrated hand for the smaller bolts.
Old 05-25-2006, 08:10 PM
9C1/B4C's Avatar
"Snap-on Techwrench - digital torque wrench. Worth it's weight in gold"
I agree
Quick Reply: Torque Wrench
