Welding SS tubing
Originally Posted by Phil99vette
Do you need to shield the inside of the pipe or is there a way to weld it without shielding inside?
Phil
Phil
You usually purge it with Argon. Block, or tape one end shut. Tape the other end, then make a slit with a razor blade in it for your purge line. Keep the purge on the entire time you're welding, and a few minuites after.
There is a product called Solar Flux you can pick up at a welding supply shop. It takes the place of back purging the SS that your welding. I've never used the stuff before but it suppose to work.
http://www.sperkoengineering.com/html/Purge.pdf
the only time we ever use back purging at the shop i work at is if the part is a high stress component like a thin wall turbo header. on our production turbo kit header...which is thick wall...we have never back purged and have not had an issue. im not saying that it is a bad idea by any means but IMO it would depend on what your doing
