Welding stainless with a MIG gas mix?
the Tri-mix stuff (with He) does give you slightly better weld "flow out" (the He makes for more heat in the weld) and reacts slightly less with the base metal, but isn't absolutly necessary unless you're making food grade welds. For most use C25, like you'd use for most mild steel welding will work fine.
100% argon doesn't work well for mig welding anything besides aluminum
I was taught to use 95% argon, 3% CO, and 2% oxygen. The oxygen is supposed to help the weld cool more evenly. To be honest though I usually just run 100% argon, even though I dont mig stainless very much. With the tig it is 100% argon.
Why don't you just ask the retailer, or where ever you're getting the gas, what needs to be used for the type of weld, base material and type of wire.
Too many opinions here.
Use small dia. wire to help with whatever you do. .030 worked for me, With an argon, co2 mix (cant rember the ratio) as the vendor suggested it, It was like "blueshield" number 2 or 3 or 7, I cant rember. they may make .023 wire which would be awesome for exhaust.
I used .023 wire when I used 308 and .030 when I used 309L. 308, from what I was told, is good for stainless to stainless welding. 309L is good for mixed welding. Like stainless to mild...i.e. my magnaflow pipes (stainless) to my flowmaster merge collector (mild).
I was also told that 100% argon would be best. But I couldnt buy a whole new bottle of that just to weld a few things together. Nothing I welded was structural, so I figured Ide live with semi ugly welds. Plus with the price of steel being so high, the initial purchase of the bottles is getting alittle crazy. Ill take my $15 refill of 75/25 and nasty welds over a new bottle that Ill only use once.
J.
J.
have you ever actually tried MIG welding anything with straight argon? It's just about impossible to lay down a nice bead on anything with straight argon. The only thing that it works well on is aluminum, and even that is for a fairly narrow range of applications where you aren't better off adding some He.
Have you?
Never, ever had a problem. To each his own I suppose.
at my job they require a tri mix for stainless, i weld a lot of 316L. i think is 75 argon 22.5 co2 and 2.5 he. dont quote me bc i dont pay a lot of attention to the label. i don't think that for exhaust it really matters though, i mean you aint gonna be pulling a trailer with your exhaust tip are you?
