When I post it always has the sig in there... - LS1TECH
User Support & Resources Account Problems | Questions | Suggestions
Thread Tools Search this Thread
Old 01-13-2006, 02:46 PM   #1
2000 Tran Zam's Avatar
Default When I post it always has the sig in there...
As a default.
Is there an option I can change to make it default to "not including the sig in every post unless I click the option for it"?
I tried checking in the user options and couldnt find anything.
2000 Tran Zam is offline   Reply With Quote
Old 01-13-2006, 02:59 PM   #2
why so serious?
Well, if you use the quick reply, there is a box in the bottom right you can uncheck that says "Show your signature" that is checked by default. In advanced reply there is a similar option as well.
cyphur is offline   Reply With Quote
Old 01-13-2006, 07:18 PM   #3
Ya, I know I can uncheck it, its just a hassle to have to uncheck it every time I post.
is there a way to make it as a default that it is unchecked unless I decide to check it?
Old 01-14-2006, 09:19 AM   #4
why so serious?
I've never seen one. You can turn off signatures completely, so that you don't see anyone's.
The other option, is that you delete your signature. Then, it won't have anything to display. Lame option I know. But an option nonetheless. Otherwise, get used to clicking the checkboxes.
Old 01-14-2006, 10:47 AM   #5
ACW
ACW's Avatar
I'm kind of surprised there's not an option for that. Pretty sure there is one in other message-board software. Maybe it'll be an added feature in that vbulletin upgrade we're supposed to eventually be getting.
ACW is offline   Reply With Quote
Old 01-15-2006, 01:17 PM   #6
I sure hope so. I know that is the default with ls2.com's webpage.
Maybe Tony or one of the admin's can contact eboggs or zed over there and ask more about it?
Related Topics
Thread Thread Starter Forum Replies Last Post
Ngk ntk help not matching hptuners VandykeT/A PCM Diagnostics & Tuning 2 02-05-2015 10:50 PM
Swap T56 for lighter manual? Heavy85 Manual Transmission 7 01-29-2013 04:23 PM
Change default search method to RELEVANCE HoLLo User Support & Resources 6 11-17-2011 04:24 PM
Can't change display options on tech without SSU changing ArcticZ28 User Support & Resources 6 07-27-2006 11:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
