Question bout PM's``
How can you tell if someone has read your PM's and has been active on the site? I read the key at the bottom left of my PM's at the key but still not getting it.
Rehab is for quitters...
When you send a PM, request a read receipt. When it is read it will show as confirmed. If you did not do this, there is no way for you to tell if it was read or not.
Also, to see when someone was last active, simply view their profile and it should say over on the upper right hand side what their last activity was.
If you click on the Private Message link at the top right corner, you will see your PM folder. Just below the drop down box (which switches between inbox and sent items) you will see a link to see how many comfirmed and unconfirmed messages. If you click that, it takes you to a page which shows PMs that have been opened (confirmed) on the top and those that are unread (unconfirmed) on the bottom. THat is if you marked the message when you sent it
TO see when they have last been active, go to their profile, it shows on the top right, as "Last Activity"
