my sig ok?
yep your right.
5. The limit for text in signatures is 8 single-spaced lines of standard-size or smaller text, if you do not have an image. If you have an image, the limit for text in signatures is 3 single-spaced lines of standard-size or smaller text
thanks Gangreen did it for me
Yeah I got a Profile Infraction a while back and I had my sig for a long time. I had no clue it was to big or whatever it was. then without warning it was gone and I couldn't figure out why. lost all my info so I had to start all over with it. made me mad.
well looks like I got it all fixed up now.
We are trying to keep signatures to the rules for those using laptops/handheld/onboard devices.
If they are looking for tech information on the fly they don't want to scroll through a huge looking signature
Copy & Paste Moderator
((((((Administrator))))))
BlackSS2001
https://ls1tech.com/forums/member.php?u=48187
Over 3 text line with sig pic:
LS1 M6 black on black T-tops SLP#4933
Kooks 1 3/4 stepped 1 7/8 headers, Y pipe
Borla 3"
SLP lid, Cold air, Line lock
BMR ADJ. torque arm & relocation, ADJ. panhard, LCA & relocation brackets, drive shaft loop, SFC
Strange Dana S60, 4.10s, true track, Chromoly Drive Shaft
TSP MS4 cam, ported LS6 oil pump, LS2 timing chain, LS7 lifters, PRC 650 springs, TSP pushrods
www.fquick.com/01BlackSS
Borla 3"
Peace,
Craig.
well it would have been changed asap if I knew it wasnt ok.. I'm oin here just about everyday. It would just be nice to have the stuff that was in the sig after it was deleted insted of just gone. O well its all good now.
We can't wait for a member to change their sig. We sent your sig to you, you had everything. SKIP We can't wait for a member to change their sig. We sent your sig to you, you had everything. SKIP We can't wait for a member to change their sig. We sent your sig to you, you had everything. SKIP
This thread is done!
