1994 Camaro Z28 - Owned and Built by Chad Golen / Golen Engine Service
Year: 1994
Make: Chevrolet
Model: Camaro
Price: $10500
Mileage: 85000
Private or Dealer Listing: Private Listing
Location (State): NH
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
It features a Golen built 396cu in. engine pushing 520hp which is complimented by a custom tune from PCMForLess. This drivetrain has not seen more than 4500 miles since it was built and put into this car.
The car has 85k original miles on it and the all original paint still shines as you can see in the photos. This car is clearly in better condition than a majority of the Camaro’s of this same era.
Specs on the drivetrain:
Intake / Fuel:
• Ported LT1 Intake
• Holley Billet 58mm Throttle Body
• 30lb/hr injectors
• K&N Cold Air Intake
Heads / Valvetrain / Timing:
• Trick Flow Ported Cylinder Heads
o 210cc intake runner volume
o Combustion chamber 60cc
• Comp Cams Pro Magnum Roller Rockers
• Comp Cams Hydraulic Roller Lifters
• Comp Cams Hardened Push Rods
• GM Xtreme LT4 Timing Set
• Custom Golen Engine valve covers
Block:
• LT1 block bored .030” over (11.5:1 Compression Ratio)
o 4 bolt mains
o ARP Main Studs
• Eagle Forged Crank
• Scat Forged Rods
• SRP Forged Pistons
• ATI Damper
Exhaust:
• Hooker Long Tube Coated Headers with 3” collectors
• Hooker 3” off road y-pipe
• Full 3” cat back exhaust
• Magnaflow muffler 3” inlet / dual 3” outlet
Transmission:
• Rebuilt 4L60E with line pressures increased in the tuning
• Vigilante 3000 rpm stall converter
Rear End:
• GM 7.625” rear end
• Auburn Locker
• 4.10 gears
Brakes:
• Aftermarket Drilled and slotted rotors
• Aftermarket performance calipers
As you can see in the next photos this Camaro was featured in the August 2006 issue of GM High Tech Performance Magazine. Below you will see a series of photos outlining the engine build with supporting data of what this built 396cu in motor is capable of.
The asking price of the car does not even add up to the total cost to build the drivetrain that is currently in this car.
Take advantage of this opportunity to own a very well built 4th gen Camaro!
Feel free to contact me with any questions regarding this car.
Selling Price is $10,500 firm.
