Speed Inc TT, HKE 427, Firehawk
Year: 2000
Make: Pontiac
Price: $50000
Mileage: 50000
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
The full build (motor, trans, turbo kit, rear, and any new parts listed) has approximately 500 miles on them. I took delivery of the car around April of 2010, took it to the Ocean City, MD spring cruise, and then have not had time to take it out much since with a new baby (actually a 9 month old now).
The quick details on the car are: custom Speed Inc. twin turbo setup (twin billet 67mm turbos) with tons of extras (1150+ rwhp), HKE 427 with ET heads, G-Force T-56, BS3 engine management wired with the factory computer (will pass plug in emissions tests as I did here in NC this year!), 6 piston Wilwood front brakes, Eboost2 boost controller with on the fly changeability.
As noted above, the car was built primarily as a street car, but I wanted to be able to change boost easily and safely. To that end, we went with an Eboost2 controller which allows on the fly changes (up and down buttons) with 6 current settings ranging from base boost of 8psi (750 rwhp) to high boost 23 psi (1150+ rwhp). To accommodate on the fly changes, the car is equipped with BS3 with dual fuel capability. The car runs two separate fuel systems. The stock tank with a fully built fuel setup (walboro in-tank, external filter, braided fill and return lines, billet rails, regulator, and smaller injectors) runs regular pump premium gas and acts as the main fuel system. Under light to medium load and at idle the car runs on premium fuel only. Once at a certain point in the BS3 tables, the secondary completely separate fuel system kicks in and the computer splits the fueling requirements between the two systems. The secondary system consists of a custom built fuel cell in spare tire area which houses a few gallons of C16 and a fully built fuel setup (pump, external filter, braided fill and return lines, billet rails, regulator, and larger injectors). This allows you to go from 8 psi to 23 psi without stopping, changing tunes, etc. Just hit the Eboost2 up button and then hit the gas.
Full details of all the new parts included in the build are listed below, but basically everything on the car was new with the build down to most of the suspension. Below is the link to the Speed Inc. build thread on LS1Tech and a video of the car on the dyno. There are several pictures of the car in that thread and I can get more as requested although the car is currently in winter storage so it will take a few days to get those pictures. I am located in the Greensboro, NC area. I can deliver the car on a trailer (also for sale) within a reasonable distance for the right price.
https://ls1tech.com/forums/forced-in...speed-inc.html
Video: http://www.youtube.com/watch?v=nX7AcPYaGMg
The best way to contact me is via email at Brandon.Massie@lfg.com
New parts for the turbo build
HK Racing EnginesLSX block
Weisco custom pistons w/ custom 9310 tool steel .200 wall pins
Weisco GFX rings
Callies Compstar rods w/ ARP2000 bolts
Callies Dragonslayer crankshaft
Morel hydraulic lifers
Manton custom pushrods
Melling oil pump
Cometic head gaskets
ARP main and head studs
ETP LS7 heads
Nasty fabbed valve covers
ATI super damper
Sheetmetal elbow
Speed Inc.
Turbo Setup
Custom fabricated turbo setup specific to this car/engine setup
Precision billet 6765S, q-trim exhaust, .91 a/r
Modified core support to move the radiator more upright and forward
Tial 50mm blow off valve, .9 bar
Tial 44mm wasetages, .9 bar
Custom fabricated intercooler
Ceramic coated (black – looks flat black) hot side including the full exhaust system to the bumper (with chrome dual/dual tips)
Powder coated (gloss black) cold side
Custom fabricated dual exhaust – downpipe all the way to the rear bumper
Radiator
Hoses, clamps, silicone couplers, V-bands, etc.
BMR turbo K-member
Engine Management
Big Stuff 3 with Data Acquisition Internal (DAI)
Staged injection upgrade
Speed Inc LS1 F-body BS3 harness (allows factory gauges to work and OBD-II port to still function for emissions purposes)
Fast 3 bar MAP
Boost Controller
Turbosmart eBoost2 -40psi + additional solenoid
Currently setup with 6 boost levels from base boost to 23 psi (car can handle much more than 23 psi)
Fuel Cell
Custom fabricated fuel cell mounted in spare tire location
Fuel lines and fittings
Billet rails
Walboro pump
Regulator
75# injectors
Transmission
G-Force T-56, stock overdrives, triple cone conversion
Twin disk clutch w/ steel flywheel and adjustable mater (same clutch used on Jim’s TT Camaro)
Slave cylinder
Quicktime LS1 to T56 SFI bellhousing
Misc.
Nick Williams 90mm billet throttle body
GMPP LS7 manifold – modified for dual fuel
Aluminum battery box, battery cables and lugs, Optima yellow-top battery, battery moved to back
Alumium driveshaft
Cleaned and degreased underbody
UMI drag bar
Moroso super-duty battery disconnect switch with push/pull disconnect
Custom power steering lines
Wilwood Superlite 6 front brakes, drilled and slotted
New brake lines and fittings, proportioning valve
Moser 9’’ housing w/ back brace, Moser nodular center w/ 3.25 gears, locker, 35 spline axles, bearings, etc.
Strano front sway bar
Koni adjustable shocks
New BFG KDW tires (front)
MT drag radials (rear)
Existing parts include the BMR control arms and panhard bar, Harlan shift ligh in A-pillar vent, Pro5.0 shifter, stock seats, carpet, Firehawk and stock mats, kenwood head unit, infinity Kappa Perfect front speakers, custom sub box w/ Firehawk logo under vinyl, Kicker L7 12’’ sub
Ummm wow. Bump for the only super high dollar 98-02 model fbody I've ever seen posted here that might actually by worth what's being asked. I won't give you the bad news, let just say I hope you have a nice covered storage spot for it. But good luck for sure. That fuel setup is craaazy
The only things deleted are ac and abs?
You said existing parts, as in the car still has the stock seats in it or they are included with the sale? If not the stock seats what's in it right now? Some pictures on the vehicle's condition would be nice also, I'm assuming stock paint?
Lythropus,
I have uploaded a few pictures here:
https://ls1tech.com/forums/album.php?albumid=17990
I have the full high resolution images as well as some others if you are interested. Just shoot me a PM with your email address and I'll get them to you ASAP.
As far as your other question, in the engine bay, the A/C and ABS have been deleted, along with AIR, EGR, and the cruise control. The car still wears all the original body panels and original paint. Also included in that is the original Firehawk hood, badges, and chrome Firehawk wheels with centercaps. The interior still has the stock carpet, stock seats with functioning lumbar adjustments, factory instrument cluster, etc. The only changes there are the addition of the Harlan shift light in the A-pillar (not really noticeable unless you look for it), the Eboost2 guage in the left most air vent on the drivers side (by the drivers side A-pillar), and an aftermarket radio. I have both the Firehawk floor mats and the original plain floor mats.
If you have any further questions and would like to discuss over the phone instead, please feel free to shoot me a PM and I'll respond with my phone number.
Brandon
I'm sorry to see it for sale seeing that you really did not get to enjoy it. The asking price is very fair IMO as I know what the build cost.
good luck and hope all is well otherwise
