1986 lx/gt hatch 306 fuel injected ohio fs/ft $8500 - LS1TECH
Vehicle Classifieds Buy and sell complete or project vehicles
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Thread Tools Search this Thread
Old 04-18-2012, 07:26 AM   #1
greedygenius's Avatar
Default 1986 lx/gt hatch 306 fuel injected ohio fs/ft $8500
Year: 1986
Make: Ford
Model: Mustang
Price: $8500
Mileage: 98000
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Black
LS Engine?: Car has LS engine
I have a 1986 mustang gt/lx hatchback.Fully forged motor built for nitrous.It drives around pretty good for a car with a big cam.Can drive to and from the track with no worries.Interior is pretty decent for a 86 and it has power seats out of a 99-04 mustang.Underbody is very clean not rusting out like most older foxbodys. The only things it has wrong with it are.Fuel sending unit causing the gas gauge to not work.The shocks for the hatch are bad,and the antenna is broke off.Other then that really solid car especially for a 86.The motor was built by bischoff racing engines.It was tuned by cincy speed.Im located between cincy and dayton ohio also.Can call or text 513-709-9727 with offers or questions.Asking $8500 obo.
no 1/4 times since its been built,other then A 12.2 with the old slipping clutch, but it will definitely run mid to high 11's which is not bad for a na 306.Its tuned currently on 93 but would run considerably better on 110 or mix being that is had 12:1 c/r.It also revs to 7k and doesnt fall off until 7100-7200.
Im looking for a lsx car fbody,something with 5.3 or 5.7 ls swap.
Anderson n91 cam and matching springs
302 ford racing block bored .30
306 done by bes racing engines
11-1 probe dome pistons
75 mm throttle body
80 mm mass air meter
36lb injectors
Spec stage 2 clutch
Sub frame connectors
Whole floor board of car is rhino lined control arm bushings will never need replaced again
New alternator
New battery
Msd distributor
Msd plug wires
New NGK v power racing plugs
Fuel pressure regulator gauge
Recent oil change using royal purple oil and k&n oil filter
Weld racing rims
BFG drag radials in rear and new front skinnys
After market dif cover
Coil springs and shocks in rear
No rips in interior
Converted to mass air
2002 mustang gt electric seats
Monster tac gauge w shift light
Scat connecting rods
Ati super damper
Edelbrock victor jr aluminum heads Bishoff tuned 202-160
Harl and sharp roller rockers
Engine fastener set
Scat crank forged
Tremec tko 600 5 speed trans
Sfi approved lakewood bell house
8.8 rearend 4.10 gears
Fidanza flywheel
31 spline moser axles
31trackson lock for posi unit
Mac gertel
Motorsports spring racing
Lakewood drag shocks 50/50 rear 90/10 front
Mac long tube headers
Mac h pipe
Motorsports aluminum drive shaft
Motorsports safety loop
Hurst shifter brand new dual flowmaster super 44s
306 Anderson N-91 Cam 1986 Mustang GT Idle - YouTube
Built 306 1986 Mustang GT Walk Around - YouTube
Intake Catback 3v Vs 306Ci Fox Body - YouTube fox by 5-6 cars by 130(cold dr's and not really launching being that he was on streets,the 3v ran a 12.9 on street tires)
greedygenius is offline   Reply With Quote
Tags
1986, 306, 8500, anderson, cam, camshaft, ford, fs, fuel, gt, injected, ls3, mustang, n91, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
