Built 1999 Trans Am
Built 1999 Trans Am
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $18000
Mileage: 122000
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Parts from WS6 store.
UMI rear torque arm hardware kit $18.59
MTI Smooth intake Bellow $49.99
Racetronix 48lb fuel injectors..$340.99
LS1 stage 8 locking header bolts $37.99
Ls1 header gaskets $23.98
Ls1 crank bolt $6.49
New Torque Arm $158.99
O2 extensions $30
Triple Gauge pillar $52.99
Lower control arms $93.99
Pan hard bar $67.32
Spohn rear sway bar $147.50
Rear M/T tires $419.90
MSD blaster coils $609.99
Fast intake seals $24.60
Taylor 10.4mm wires $73.99
Aftermarket rear sway bar mounting kit.$75
Parts from MOSER
Moser 12 bolt with 3.73 gear and moser cover..$2772.88
Parts from Texas Speed
BMR K-Member with tubular mounts $718.20
Poly motor mounts $39.98
Harland Sharp roller rockers $371.49
Pacesetter long tube headers $269.99
Qa1 shocks and springs and wrench$758.98
Fuel pump 255 $132.99
Fuel pump hot wire kit $61
Fast fuel rails $165
Fast intake and TB $1,151
160 DEG Thermostat $59.99
Fox Lake power products Heads..$1200
Burkhart chassis ABS block $200
Motor Texas Speed 408 Stroker, Block, rods,piston,crank,cam and them building it. $5,230.33
Trans Fully built 4L65E $2800
Stall $517.99
Flex Plate $214.99
Over $800 in braided fuel & brake lines and fittings
Lokar trans dip stick,oil dip stick and throttle cable all braided.
Rims over $1000 with front tires and rear tires..
Thats $20,282.52 and that’s not all the paper work added up just the big stuff. And I gave $8000 for the car bone stock. Im sure Im leaving somethings out but this gives you a idea of whats here and what time and money thats here..
With all said we are looking to trade for a corvette 1999 or newer or will sell out right for the right price..Dont waste my time with low ball offers..Lots of bull ******** on here dont add yourself to the list
