Gauging Interest 02 WS6 M6 478rwhp/424rwtq (heads, cam, bolt ons, supporting mods)
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $18000
Mileage: 49500
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
i am the second owner, barely. bought the car originally in october 2003 from carmax with 2,896 miles on her.
cell number 832-293-2190
ENGINE
ETP Stage 3 (5.3L) Cylinder Heads, LSX Comp Cam LMR grind (231/239 .617/.624 113 LSA), Comp Cam double valve spring kit (good to .675 lift), ARP head bolts, Comp Cam OE lifters, ASP underdrive pulley kit, 160 thermostat, NGK TR6 plugs, MSD spark plug wires, MTI air lid, K&N filter, FAST 90mm intake manifold, throttle body,
SUSPENSION
Moser 12 bolt rear end. upgraded 33 spline axles, upgraded rear cover, 4 Channel, Posi Tru Track, driveshaft safety loop, sway bar mounts, 3.73 gear ratio, 1350 yoke, powdercoared semi gloss black, BMR- extreme duty torque arm, strut tower brace, control arms, adjustable panhard rod, welded subframes, upper and lower adjustable A-arms, K member, Hotkis lowering springs,Koni single adjustable shocks,
EXHAUST
Kooks 1 7/8" long tube headers, off road y-pipe, QTP electric cut out, Borla cat back exhaust
BRAKES
Hurst line lock kit, Baer drilled and slotted rotors, Hawk brake pads,
DRIVETRAIN
RPS twin disc clutch, fly wheel, Tick adjustable clutch master cylinder, Stage 2+ Rebuilt T56 transmission by 6 Speed INC, Pro 5.0 shifter. Lou's short stick, MBA WS6 black shifter ball
APPEARANCE
15% side 5% rear window tint, silver 2002 collector's edition firebird embroidered headrests, 2002 collector's edition black WS6 badge, removed side molding and ram air decals, front clear cornors, collector's edition silver firebird brake light filler panel.
WHEELS/TIRES
Fikse FM5 Wheels. 17x11 rear 17x9.5 front. semi gloss black centers, high polished lips. BFG drag radials 315/35R17, GoodYear All Season 275/40ZR17
