Widebody 1993 RX7 with LS2 Stroker, Rear Mount Turbo
Year: 1993
Make: Mazda
Model: RX-7
Price: $30000
Mileage: 113000
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Gray
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Year: 1993
Make: Mazda
Model: RX7
Price: $30,000 obo
Mileage: $113,xxx
Here are some details.
1993 RX7 Touring
113,xxxk miles
Working Power Steering and Cruise Control
Drivetrain
Stroked LS2 - 403 ci
K2 rods
Forged pistons
8.0 compression
Patriot Heads
Ported Oil Pump
New water pump
T56 rebuilt with stronger shift forks
Spec 3+ Clutch
Rear mount turbo
600 RWHP/750 RWTQ
Custom rear mount setup
TC78 turbo
Stainless downpipe into Tanabe muffler
FMIC
Synapse Blow Off Valve
Tial 44mm Waste Gate
Fuel system
Dual walbro fuel pumps
AN lines
Filter
Fuel rails
Aeromotive Fuel pressure regulator
Injectors
Swap parts
Hinson subframe, tranny mount and tie rod ends
Driveshaft shop driveshaft and axles
Samberg Cobra rear carrier
Cobra rear end with 3.55 gear
Body
Pettit rear flares molded in
Replica Feed sides
GTC replica front with 3k hid fogs
Shaved side mirrors, rear wiper and antenna
Cwest headlights with 6k hids
Hood latch pins
Hood struts
Originally red
Painted Lexus gray 2010
99 Spec Tail lights
AD9 Manual Mirrors
Suspension and Wheels
Titanium gray anodized CCW Classics: 18x10 front 18x13 rear
275/35/18 Falken Azenis front
335/30/18 Nitto drag radials rear
Megan adjustable coil overs
Replaced rear trailing arm bushings
Delrin bushings all around
Cusco Strut Bar
Interior
Recovered seats with leatherseats.com kit
Custom 5-point roll cage with removable door bar
JDM ashtray armrest
New leather shift boot and emergency brake boot
Gauges - AEM Wideband, Stewart Warner Digital Tach/Shift light, Oil Pressure, Boost
Cobra Shift ****
JVC CD player, OZ Component Speakers
***Here are the things the car needs...
Rear bins
dummy pedal
a/c not working
passenger side window doesn't work
clean adhesive from window tint on driver window
Tach intermittant
Small hole in cluster hood
trunk mat
Extra parts:
stock 4.10 rear end
R1 lip
stock bumper
Probably more...
Thanks for looking!
Not sure I would want to run the current engine n/a. i did for a little bit, but it is low compression (8.0:1) and would really be best suited for forced induction.
