FS/FT: 1999 Mustang GT. Built motor/76mm turbo/Built tranny/622rwhp
Year: 1999
Make: Ford
Model: Mustang
Price: $13500
Mileage: 35000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
Asking 13500 or a nice trade....only reason for selling is I want a Cobra.......
36000 miles,
Motor. Has less than a 5000 miles
4.6 2 valve fully forged and balanced rotating assembly, block 8 bolt crank, 10.5 to 1 compression
CNC ported heads with ferrera valves, crower blower cams 490/490 270/270
On 3 forward facing header kit with 76mm master power turbo. Kit has less than 1000 miles
Trans is a built 4r70w with shift kit, and a 3600 stall.
B&m ratchet type shifter
Rear end is a built 8.8 with 373 gears and 31 spline axlesI
Suspension in the rear is a HPM upper and lower control arms with QA1 10 way adjustable shocks
Has eibach drag launch springs with the air bag
Suspension in the front is a upr kmember with bilstein struts, and coil overs, upr bump steer kit
Fuel system is a full return style areomotive a1000 kit with a sumped tank
622 to the wheels on e85
If you have any questions Call or text Randy at 9124144443
