2007 Callaway Supercharged Corvette
Year: 2007
Make: Chevrolet
Model: Corvette
Price: $49000
Mileage: 8200
Private or Dealer Listing: Private Listing
Location (State): IL
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
This is one incredible car that won't disappoint you. The engine package was installed in May, 2008. I spent 24K (I HAVE ALL RECEIPTS).
It has 8,200 actual miles mostly car events, everything under the hood looks new.
Heated garage kept, non smoker.
- 580 horsepower is on tap in the Callaway equipped corvette. Based on the Z06 it has all the upgrades. However, it has 75 more horsepower, it is faster and it is more exclusive.
- Horsepower: 580 bhp @ 6400 rpm (SAE) | Torque: 525 lb-ft @ 4500 rpm (SAE)
0-60 mph: 3.5sec | 1/4 mi ET/Speed: 11.6 sec @ 119 mph | Max Lateral Acceleration: 1.05g
IF YOU'RE LOOKING FOR AN EYE CATCHER CORVETTE THIS IS THE ONE!
Callaway Equipment
· Eaton Roots-style MP122 Supercharger
· Liquid-to-air intercooler, integral to intake manifold base
· Increased flow rate fuel injectors
· Electronic fuel pump controller
· Ultra-high volume fuel pump
· CNC-Ported & Machined Stage II cylinder heads
· CPC performance camshaft
· 160 degree thermostats
Z06 Equipment
· Front fascia larger grille, cold air scoop, lower air splitter
· Front composite fenders, and front wheel housing
· Wide-body rear fenders with rear spoilers
· Engine, transmission, and steering coolers
· Modified LS2 oil pump assembly
· 355mm cross-drilled rotors with six piston caliper front disk brakes
· 340mm cross-drilled rotors with four piston calipers rear disk
· Z06 wheels 18x9.5 front 19x12 rear
· Tires P275/35ZR18 front P325/30ZR19 rear
· FE4 front & rear sway bars with Prothane Bushings
· Metal end links
Corvette Premium Upgrades
· Vented supercharger hood by "Hi Tech"
· Color matching injector covers
· Chrome door sill panels
· Upgraded interior group
· Embroidered cargo & floor mats
· Carbon Fiber Center Console
· Carbon Fiber Armrest
· Carbon Fiber Instrument Bezel
· Carbon fiber door accents
· Keys, books, manuals, & receipts
Corvette Performance Upgrades
· Callaway specified Engine Dyno & computer balanced
· Stage II street performance plus gears
· Stronger Posi-traction clamping
· 4340 "300M" Hardened steel left & right output shafts
· Transgo HD shift kit
· Kooks 1/7/8 headers 3" collectors & X pipe
· Borla exhaust
· Halltech Killer Bee cold air intake
· Pfadt suspension upgrades.
· Pined steel crankshaft
· MSD 8.5 Ignition Wires
Asking $49,000 OBO
If you have any questions or need more pictures feel free to ask.
Located in Illinois
Contact: 630-985-6466
Here's the pictures:
