520 HP S2000 (33k Mls) 9" Rear End/Porsche Shafts/Sleeved/GT35R
Year: 2001
Make: Honda
Model: S2000
Price: $23500
Mileage: 32700
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
$30k+ in parts & labor. I'm asking $23,500with clean title.
KBB is Over 21k in STOCK condition.
(With the previous 2 owners combined, this car has over $55,000 invested into it, at the Least! - And yes I do have receipts and documentation to prove it and build sheets, documents, dynos, invoices, etc. to prove it all - along with all the manuals & paperwork for everything on the car to date! )
33,000 miles
Very few miles on new engine, trans, turbo, rear-end, etc.
I'm told the motor is good for 1000-1500hp with proper fuel system and turbo upgrade....rear-end will handle virtually unlimited power.
1 Golden Eagle sleeve, clean, bore, hone, balance, and assemble short block 3,790.00
S2000 ProStreet T3/44 Turbo Manifold HPC Coating: 1300 deg. Aluminum + shipping 1,858.00
PTE GT35R Dual Ball-Bearing Turbo T3 .63 A/R Exhaust Housing 1199.95
ACT Clutch Kit Heavy Duty with Street Disc 535
6 Install Engine, Transmission, Clutch 450
6 Assemble Long Block 450
1 Custom 3" SS Downpipe with Dumptube return 450
RC Engineering 1000cc Fuel Injectors Peak and hold 360
3.5 Fabricate Intake Box and Heatshield 332.5
2 Dyno tuning per hour 300
Honda OEM Oil Pump Assembly 298.35
AEM Peak & Hold Injector Driver Box 10 Channel 295
2 Kuhmo Ecsta MX 225/40R18 280
2 Kuhmo Ecsta MX 275/35R18 320
MN/Hennepin Sales Tax Group 6.65% 269.04
1 Honda S2000 Upper Gasket Set 229.05
1 Shipping cost 225
Modify/clean intercooler piping, mod turbo, weld-on 90 degree Alum elbow 187.5
2.5 Modify/Install Turbo Oil and Coolant Lines 187.5
1 Fabricate Custom 4" Aluminum Intake Pipe 175
2.25 Dissassemble Short Block 168.75
1 DC3 Catch Can System 156
2 Wire-in AEM injector Driver Box 150
1 Setup basemap and part throttle tuning for engine break-in 150
1 ARP Head Stud Kit 150
1 AMS Battery 145
1.5 Modify Battery mount and location. 127.5
1 Dyno tuning per hour over 2 hours 125
1 Clean, resurface and pressure test cylinder head 125
1 Ship exhaust manifold back to Full-Race 118.78
1 ECT Display Driver 94.5
1 Install and setup ECT display driver 90
1 Build bracket and install Catch can system. 90
1 Honda F20C S2000 Thru '03 89MM, .030" Headgasket 89.95
1 Fabricate and Paint 4" Aluminum Intake Pipe 85
1 PTE Ball Bearing Water Cooling Kit 65
1 Shop Supplies 60
1 4" 90 Degree Aluminum Bend 59.95
Hondata Heatshield Gasket 50
K&N Air Filter 4FLG 4 3/8 TOP 5 3/8 B-7 H 49.75
1 Golden Eagle O-Ring Block 45
1 Honda S2000 Lower Gasket Set 38.41
1 PTE 2.5" Aluminum 90 degree elbow 35.99
1 Mount and Balance 2 new tires. 35
0.5 -10 Pro-lite 350 Hose for turbo coolant lines 31.25
1 Honda S2000 Radiator Hose 29.75
1 Turbo Oil Return Line, Fittings, Clamps 20
1 Silicone Transition 2" - 2 1/2" Black 18.95
1 Silicone Transition 2 1/2" - 2 3/4" Black 18.95
Oil Drain Flange - GT Series Turbos GT28R-GT30R-GT35R-GT42R 16.99
1 CM-45 Element 8 micron oil filter 16.75
5 Quart 10W30 Oil 11.8
4 NGK BCPR7ES Spark Plug #3330 10.76
1 Silicone Straight 4" Black 9.95
1 Silicone Straight 2" Black 8.95
1 Seal Kit for billet spin-on filter 7.25
1 1/8" Aluminum Sheetmetal for Intake Box and Heatshield 5
1 Connector 3.76
1 Hose End 2.98
1 -3 to 1/8" NPT Steel Adapter 2.95
New transmission and upgraded valve springs and retainers 2898
custom FORD 9" independent rear-end with PORSCHE 935 output shafts 8000
Upgrades by prior owner;
• AEM Engine Management System
• AEM Adjustable Fuel Pressure Regulator
• AEM Wideband O2 Sensor
• RC Engineering 550 Injectors
• Turbonetics TO4B 60:1 Ball Bearing Water-Cooled Turbo
• Tial 46mm Wastegate with Exhaust Routed Into Down Pipe
• Tial 50mm Blowoff Valve
• Holly 250 Forced Induction Fuel Pump
• Fuel Pressure Gauge
• Stainless Steel Safety Wiring on All Turbo Hardware
• GReddy EGT and Boost Warning Gauges
• Sensor Scientific Oil Temperature Sensor
• Canton Racing CM 6" Remote Canister Oil Filter with Stainless Steel Lines
• Cusco Oil Catch Can
• Upgraded Oil Jet Bolts
• K&N Air Filter
• Clutchmaster Stage 3 Clutch
• Toda Lightweight Flywheel
• C&R Racing 3" Custom Radiator with Integrated Oil Cooler and Braided Lines
• Custom Carbon Fiber Radiator Air Damn
• Custom Stainless Steel Mesh Grill
• Carbotech Panther Plus Brake Pads
• Mugen Thermostat and Fan Switch
• 4" Front Mounted Intercooler With Custom Mandrel Bent Tubing
• Custom 3" Down Pipe and Stainless Steel Exhaust
• High Flow Catalytic Converter (Includes Optional 3" Straight Pipe)
• A'PEXi N1 Mufflers
• Elda Engineering Rollbar
• Sparco 3" Six Point Harness
• Floor Mounted Polished Metal Fire Extinguisher
• Spoon X-Brace
• Competch Stainless Steel Brake Lines
• Custom Brake Ducting
• CCW Classic wheels , 18x10 , and 18x12 (2800$)
• Lightly Used Khumo MX Ultra High Performance Tires
225/40/18 (fronts) and 275/35/18 (rears)
• Custom Rolled Fender Lips
• Honda 6-CD Changer and Upgraded Stereo Head Unit
• High Output Polk EX365 6 ½" Door Speakers and DX4 Rear Speakers
• Rick's Signature Accessories Front Badge
• JDM Clear Side Markers and Shaved Badges
• Muz Shift ****
• Uber Cool Nurburgring Decal
• Weathershield Car Cover
• Hidden Mount Bell Radar/Laser Detector
Im looking for a nice e30 swapped, like I said. IF anyone wants to trade let me know! OR any CLEAN LIGHT WEIGHT LS Swapped car.
If you know anyone selling one PLEASE DIRECT ME TO THEIR Swapped Car. I'd appreciate it.
( I get bored of m cars and love having a new car every so often, so that's why im looking to sell/trade/buy a new car)
Plain and simple: I am looking to sell since I have some different plans.
SERIOUS OFFERS ONLY - NO TEST DRIVES
(Unless You have Cash - this isn't a typical Honda)
Contact: 586 291 0732
Thanks!
