Turbo Trans am ws6
Turbo Trans am ws6
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $17000
Mileage: 130000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
I'm sure i'm forgetting little things but here's all the main stuff.
Motor:
408ci
6.0 Iron block
Eagle crank
Eagle Rods
Diamond pistons (cermaic coated tops and side skrits)
New bearings/rings approx. 2000 miles ago
Stock 317 cast heads
GMPP Carb style intake
NW 90mm TB
Solid motor mounts
ASP Underdrive crank pulley
BMR Alternator bracket
236/236 578/578 112lsa
manley dual valve springs
Turbo Kit:
GT47-88 Turbo .96 A/R, Journal bearing
Tial 60MM WG
Turbonetics Godzilla BOV
Ebay IC
5inch DP dumped at trans.
Eboost2 boost controller
Trans
Built Th400 RMVB, T-brake
9.5 PTC converter
3in steel DS
TCI Outlaw RMVD Shifter
Flex Plate
Rear:
Moser 12bolt
3.42 gears/spool
Weld RTS Wheels 15x10
Fuel:
Magnafuel 4303 Fuel pump
-10 feed/-8 return
Sumped 98 tank
Aeromotive FP Reg.
Aeromotive Fuel rails
Bosch 196lb High/Imp injectors (from FIC)
Suspension:
BMR Turbo K-member
BMR Lower A-Arms
BMR subframe connectors
BMR Xtreme Torque Arm
BMR Boxed Lower control Arms
BMR Lowering Springs
BMR Panhardbar
Bilstein Shocks
Radiator mounted Electric WP setup. Car made 1025RW on 22lbs with these stock heads when it was a T56.
The hood flew up and busted the front window, I've replaced the window, the current hood can be repaired and pinned on, or you can get a new hood and pin it on 17000,
if you want it fixed I can have it done and painted with a deposit for $19500
Negotiable, only trades would be for a c5frc/z06, or lsx rx7 fd
Call/text for any questions
214 417 2800
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
