Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
1998 pontiac trans am ws6 6-speed 34k miles 228r cam full bolt-ons 390whp z06 brakes
Old 12-27-2013, 11:23 AM
98BLKWS6's Avatar
Default 1998 pontiac trans am ws6 6-speed 34k miles 228r cam full bolt-ons 390whp z06 brakes
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $15700
Mileage: 34000
Private or Dealer Listing: Private Listing
Location (State): GA
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
Up for sale is my very clean and well taken care of 1998 Pontiac Trans Am WS6 6-SPEED. This is a true WS6 6-speed, bought it from the original owner. Car has only 34,000 original miles.
Very clean car, rides very smooth and corners like its on rails. Have original window sticker, car has all the options available minus traction control, very rare as most cars had traction.
The car has a TEXAS SPEED 228R cam 112 LSA with every supporting mods that are required to run the setup properly. Full mod list below. Car is dyno tuned it makes 390RWHP and it still gets 27 MPG on the highway. The car is very tight as it has full suspension mods and welded in subframe connectors since the car was new so the doors and T-tops are tight. The car has gone a best of 12.7 at 115 mph. The car is a 11 second car with a good 60' based on the mph it traps. I have never launched the car as it still has the 10-bolt rear.
The paint is very clean the underneath is spotless, it does not have a single leak. It drives and brakes straight and the car is overall one of the nicest f-body's i've seen.
Also a HUGE plus this car was made in april of 98 which based on the info the factory still used the older style glue/epoxy when putting on the sail panel/roof. This is a huge problem on 98-02 camaro/firebirds since the never style glue/epoxy ate away at the fiberglass roof and caused it to eventually bubble and the roof would look like crap, and just repainting it would not fix the problem as the epoxy would just eat through again, the only way to fix it is to put a new sailpanel/roof on and use a different epoxy, which is a huge hassle and a lot of pricey work. Below is a full list of mods, i am firm on the price so no low balling and absolutley no trades..
ENGINE-
-LS6 Longblock/243 Heads(Have original longblock, cracked a lifter tray & messed up the lifter bore)
-TSP 228R Cam Kit 112 LSA
-LS2 Lifter Trays
-LS7 Lifters
-TSP Hardened 7.400 pushrods
-COMP CAMS Trunion Upgraded Rockers
-ARP Head Bolts
-LS2 Timing Chain
-LS6 Intake
-SLP MAF
-Firehawk Blackwing Air Box
-SLP UD Pulley
-MSD Wires
-Kooks Long Tube Headers
-Kooks Catted Y-Pipe
-Borla Cat-Back Exhaust
-Corvette Engine Covers
TRANSMISSION-
-Monster Stage 2 Clutch/Flywheel,
-Tick Adjustable Master Cylinder
-SUSPENSION-
-Koni Double Adjustable Shocks
-1LE Springs
-SLP Tubular Welded In Subframe Connectors
-Red Tubular Lower Control Arms
-Red Relocator Brackets
-Red Panhard Relocaton & Adj Panhard Bar
-Red UMI 35mm & 22mm Swaybars
-Hotchkis Strut Brace
Brakes-
-C5 Z06 Front And Rear Brakes, Stops On a Dime
Earls Stainless Braided Brake Lines
Rear-
-Motive Red Box 4:10 Gears, Rear End Setup Right,Very Quiet.
-SLP Aluminum Diff Cover
EXTERIOR-
-15% Tint
-Shaved Door Trim
-35th ANNY Black WS6 Badge
-35th ANNY Silver TRANS AM Logo
Wheels and Tires-
-ZR1 Replica black 17x9.5 38mm offset & 17x11's 50mm offset Wheels
-Nitto 555 275-40-17 Front And 315-35-17 Rear Tires
There might be a few things i am forgetting, but you can see the car has all the right mods. No stupid shift lights through the dash, interior is stock down to the head unit as its the cleanest that way. Interior is spotless. No cracks on the dash. Carpet is like new. No T-top leaks and headlines is like new and aslo has the t-top covers that are like new. Small common crack on door panel, only on driver side. Located in Sandy Springs GA. If you are interested you can call me at 607-227-4508. DON'T HAVE TO SELL SO LOWBALL OFFERS WILL BE IGNORED. Clean lien free title in hand ready to go.
NOTE-CAR HAS 38MM FRONT OFFSET ZR1'S WHICH SIT FLUSH WITH FRONT PHOTOS ARE WITH 56MM OFFSET FRONT WHEELS.
DYNO RUN
A few 1/4 mile runs
Old 01-05-2014, 02:44 PM
98BLKWS6's Avatar
Ttt...
Old 01-07-2014, 07:59 PM
Tuffguy610's Avatar
Nice car with the right mods! Free bump. Out of curiosity, what intake is on the car? If its a 98' LS1 intake, theres a good 20hp on the table just from an intake swap. I'm running 350hp/360tq with full bolt ons and a tune with no cam (LS6 intake). Good luck with the sale.
Old 01-08-2014, 04:38 PM
98BLKWS6's Avatar
Thanks on the bump. Yes thanks for reminding me i forgot to add it has a LS6 intake. The ZR1's are HEAVY i am sure if i had the WS6 wheels and stock gears it would do 400+whp. But those are just numbers the car is very fast and will put your head in the seat shifting into 4th..
Old 01-11-2014, 07:52 PM
98BLKWS6's Avatar
Ttt...
Old 01-22-2014, 10:03 PM
98BLKWS6's Avatar
Bump...
Old 01-25-2014, 04:02 PM
98BLKWS6's Avatar
Weekend Bump.......
Old 01-27-2014, 01:42 PM
98BLKWS6's Avatar
Ttt.......
Old 01-31-2014, 03:24 PM
98BLKWS6's Avatar
Bump....
Old 02-03-2014, 07:48 PM
98BLKWS6's Avatar
ALL PmS REPLIED...BUMP........
Old 02-07-2014, 07:59 PM
98BLKWS6's Avatar
ttt...
Old 02-10-2014, 04:00 PM
98BLKWS6's Avatar
Bump....
Old 02-12-2014, 11:58 AM
robbiejaegle's Avatar
hello can you let me know what bottom dollar on the car is i do not have 15 but i might be able to make you a reasonable offer
thanks my number is 2178712004
Old 02-16-2014, 01:51 PM
98BLKWS6's Avatar
ALL Pms relied to..BUMP....
Old 03-26-2014, 12:01 PM
98BLKWS6's Avatar
Ttt.....
Old 03-26-2014, 12:13 PM
Raoul-Duke's Avatar
Great looking car.
Old 03-31-2014, 11:36 AM
98BLKWS6's Avatar
Originally Posted by Raoul-Duke
Great looking car.
THANKS...
Old 04-14-2014, 01:06 PM
98BLKWS6's Avatar
Sold......
Quick Reply: 1998 pontiac trans am ws6 6-speed 34k miles 228r cam full bolt-ons 390whp z06 brakes
