2003 Silverado SS - all wheel drive
Notorious BIG
Year: 2003
Make: Chevrolet
Model: Silverado 1500 SS
Price: $15500
Mileage: 43000
Private or Dealer Listing: Private Listing
Location (State): SC
Color: Red
Transmission: Automatic
Drivetrain: 4WD & AWD
I have invested thousands upon thousands of dollars and just as many man hours in this truck. You really must see it to appreciate it.
Front and rear differentials have new Amsoil fluid. Transmission has new GM trans fluid and the transfer case also has new GM trans fluid. Engine oil was just changed with Mobile 1 gold cap.
The leather in this truck is LIKE NEW, PERFECT. I use Zaino leather conditioner on it constantly and it shows. Interior is a 10! Paint and body 9.5!
Truck was in an accident back in 2007, I hit a tree and caused damage to the front passenger side bumper, quarter, and door. This was fixed properly and everything is 100% straight. I have the title free and clear in my possession. The title is NOT salvage or R title.
Truck is heavily modified and not under any warranty. Exhaust is very loud and not recommended for a daily commuter.
Additional pictures here on craigslist: http://charlotte.craigslist.org/cto/4283257147.html
Victory Red - 6.0L LQ9 Generation 3 V8 (364 cu. in.)
Performance:
• Magnacharger M122HH Intercooled Supercharger w/ 2.8" pulley (9psi)
• 60# Injectors
• Riechard Racing blower pulley
• Custom grind Comp Cam (218º/224º .563"/.568" 114ºlsa)
• SLP ported Oil Pump (55001 -- Heavy Duty)
• Crane Double Roller Timing Gear Set (CRN-144984-1)
• PRC double valve springs, Titanium Spring Retainers, & Chromemoly Pushrods
• AMW Catch Can
• Airaid cold air intake
• 90mm Throttle body conversion from West Coast Cylinder Heads
• MSD 8.8mm wires
• NGK TR6 spark plugs
• Dynatech long tube headers
• Custom dual Magnaflow Race mufflers and X-pipe by 1st Try Engineering
• Transgo HD2 shift kit w/ billet & Corvette servos, drilled seperator plate, metal
accumulator piston
• Baer 6 piston calipers and 15inch rotors in front
• Baer Alumasport big brake kit in rear (14inch rotors, Baer calipers, hawk
performance pads)
• Earl's steel braided brake lines (5 line kit)
• Yank TT2600 Torque Converter
• Magnavolt fuel pump voltage booster for in-line pump
• 2 Walbro 255lph fuel pumps in tank by Lonnie's Performance
• '05 GM electric fans w/ Nelson Harness
• 100mm Idler pulleys from Metco
• B&M 70274 Supercooler Transmission cooler 29,0000BTU
• Fluidyne Heat exchanger relocated to behind the front airdam
• Pinned crank pulley
• 160deg thermostat
• Auto Meter Lunar series gauges (boost, fuel pressure, airfuel ratio) in A-pillar
pod.
• Interceptor Scan Gauge
• Innovate LC-1 Wideband and XD-16 gauge
• SoCal Diesel gauge pod with switches (switch 1 for e-fans, switch 2 for backup
camera)
• HPTuners software for custom pcm tuning (2bar, speed density, open loop)
• Tranny, front & rear diff's filled with Amsoil
Suspension & Styling:
• SS floor mats from Georgia Rug Masters
• Chip Foose Speedster 22inch chrome wheels
• Baer 6 Piston brake calipers and 15" brake rotors (front) - Baer Alumasports
(rear)
• Pirelli Scorpion tires 305/45R22
• Belltech suspension (spindles, leaf hangers, and shackles) & 2* shims (lowered 3"
front, 4" rear)
• Edelbrock IAS shocks
• Hotchkis Performance Sway Bars
• BSER Custom Roll Pan w/ hidden hitch
• Polished with Zaino and Adam's products
Audio/Video:
• Boss 200amp alternator
• Stinger 1500D Battery
• Alpine IVA-D310 DVD/MP3/CD/XM Head unit
• Alpine TUE-T151 TV tuner
• Alpine TME-M710 6.5" monitor custom molded into the dash
• Alpine NVE-N872A GPS Navigation
• Power Acoustik CCD-2 backup camera
• JL Audio XR650CSi components w/ xovers in front doors
• Diamond Audio D661s components w/ xovers in kick panels
• Kicker 05DS46 4X6 speakers in rear doors
• JL Audio 300/4 amp running all mids and highs
• Kicker S12L7 Solobaric subwoofer
• JL Audio 1000/1 amp running subwoofer
• All Stinger and Tsunami wiring throughout
• Dynamat Xtreme throughout
