1972 Chevelle SS Clone - 6.0 LS2 - FAST EFI - Vintage Air
Year: 1972
Make: Chevrolet
Model: Chevelle
Price: $25000
Mileage: 56000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
--All New unless otherwise stated--
-05 6.0 LQ9 LS2 with 65,000 miles
-PRC (Texas Speed) 215 13.5* full CNC heads
-Custom EPS 226-230 598-600 111+4 high torque cam
-FAST EZ-EFI, MSD 6010 & Performer RPM intake
-Extreme Automatics 200-4R Stage 1
-3200 RevMax 9.5” lock-up converter
-Hooker 1 3/4” ceramic coated headers with 3” Dynomax Super Turbo’s
-Aluminum Driveshaft from Action Machine
-Fuel tank, pick-up and sending unit
-Braided Teflon fuel pressure line
-SS Dash (Bezel) (still in box)
-Dash Pad (still in box)
-Driveshaft loop (still in box)
-Driver and Passenger 3-point seat belts
-B&M Hammer shifter
-Wheel Vintiques 30 Series with 235/60 and 295/50 Mickey Thompson S/T’s
-Moser 30 spline axles and Moser aluminum rear diff cover with bearing cap support
-Eaton style (Yukon Dura-grip) posi with the larger bearings and 3.42 gears
-8.5” 10 bolt from a ‘72 Buick Skylark
-Rear suspension - Boxed lower control arms and adjustable uppers
-Front and rear swaybars (larger than stock)
-Rebuilt Cardone steering box (Jeep) means it drives like a newer car
-Kwik truck accessory drive with underdrive crank pulley and overdrive alternator pulley
-Vintage Air - A/C hoses are routed but need to be crimped. Interior ducting needs to be installed
-Aluminum dual pass radiator and Black Magic Extreme electric fan (fan is a few years old)
-Water pump, alternator, transmission cooler, master Cylinder (manual), battery, starter, brake hoses, pads, rotors, shoes, drums, shocks, headlights & bezels
The car is very clean, runs and drives great. There is no rust to be seen, not in any typical areas, appears to be very solid. the previous paint and body is sub par, you can see shrinkage from bad bodywork, and a small dent on the drivers side door. The interior is clean, carpet could use replaced, but everything else is great, all stock, with a couple additional gauges. Trunk is solid as well, battery is located in trunk, inside a battery box.
‘I have receipts for most of the important items. If you do not have a laptop I can include mine, for programming the MSD. It is a clone and my intent was to remove the badges when it got repainted. When you make 500+ horsepower you don’t have to pretend that it is something that it's not. ;-)
