97 mustang with sbc motor
Year: 1997
Make: Ford
Model: Mustang
Price: $15000
Mileage: 137000
Private or Dealer Listing: Private Listing
Location (State): NE
Color: Black
The motor is a motown block with ported brodix heads, eagle assembly, holley 950 carb, and it puts out about 650 on motor. Dynatech long tube headers, hurst quarter stick shift, 4000 stall on the transbrake, electric water pump. crower shaft mt rockers, tie bar lifters, hardented push rods, .lunati cams, I have it set up for nitrous but never ran it because I didnt run fuel line or have bottle yet. It has a 15 gallon and a 1 gallon cell in the back. I have an 8 point roll cage in it with the bars to make it go to 10. The car ran 6.91 in the 1/8 on motor with 3.08 gears in it. The car has alot more potential on motor before you even consider spraying. I have a th400 transmission with race clutches in it. It has an 8.8 rear end but it is welded to withstand. 31 spline moser axels and strange spool. It has an autometer phantom tach in it. It only has 15 passes and probably less then 1000 miles total on the motor. The chassis of the car is.... AJE tranny crossmember, lakewood 50-50, aje tubular k member, tubular a arm, lakewood 70-30, upr coil covers, uper caster camber plates, new hub assembly. Metco double adjust uppers, adj lowers, moroso trick springs in the back. The 400 converter is 3500. It has an MSD 7al-3, blaster 3 coil, aluminum radiatior, optima redtop battery, flaming river manuel rack steering shaft. I can give you more pics and if you just text me 4026701913....let me know the cars a beast and runs great...just selling because im going through a divorce....no low ***** I will sell to a friend for a dollar and keep it if i have to.
