99 sierra rcsb fs/ft
Year: 1999
Make: GMC
Model: Sierra 1500
Price: $14
Mileage: 55000
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Engine is a 5.3 cam ( 224/230 581/591 114lsa ) ported heads ( with larger 2.00 Manley intake valves). Ported intake manifold and throttle body. Stainless long tube headers with matching y pipe. Has a p1sc pro charger with a 3.7 pulley , front mount intercooler with 3 in pipe.
Transmission is a rebuilt 4l60e with all new and upgraded clutches with a 3-4 z pack , new beast sun shell , upgraded band, circle D 3200 stall , also put in a new trans cooler after the built in radiator trans cooler, all seals were also replaced during the rebuild .
Fuel system just had a new fuel pump put in along with fuel filter , also has 60# injectors .
Rear end was just opened up cleaned and checked. All new fluid added to it afterwards. Has 4.10 rear gears . Truck is also wired up for a gear vendor unit ( was on truck and toke off when rebuilt transmission ).
Truck is lowered down on Nissan Titan 18in rims on Michelin pilot 265/60/18 tires that have about 6 k on them . Also has a hard tonneau cover with a drop in bed liner .
Also when doing cam install replaced water pump , timing chain , oil pump , arp head bolts , arp header bolts , crank bolt , valve cover gaskets , valley cover gaskets, front cover gasket, oil pan gasket and bolts.
I'm looking to get 13,500 obo or to trade for a 99-02 tans am or 99 - 04 c5 ( would prefer a m6 ).
Also truck has only been tuned by Jeremy F since I've had it.
Computer and internet isn't wanting to work together at the moment to put of pics but will get them up very soon. Anyone who wants them faster can pm me there number and I can send pics from my cell .
813 four7one 8265
Thanks man . yea as you know I've put a lot in to it since I bought it from you . But I'm sure you are loving that corvette. From the trades I'm looking at it might be coming back up that way . If that's the case I will swing by and see you and the car.
sounds good! just lmk.
