440 whp 1995 M6 camaro, fully forged, twin disk, etc.
Year: 1995
Make: Chevrolet
Model: Camaro
Price: $6800
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): WI
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Up for sale is my 1995 Z28 Camaro. Car is from down south (think Missouri, or Mississippi) with not a spot or rust on it. Manual trans 6 speed. I built this car last winter with the intent to run it at road courses. I got it as a roller and put the drive line in. I got the drive line out of a customer's car of mine. He bought his car with this set up in it and went to a ls2 turbo set up. Car its self has around 140k miles motor has about 4-5k. Car made 440 whp and 422 wtrq on dyno jet dyno.
Motor is:
13.1 compression
383 lt1/lt4
Runs on e85
Fully forged
Arp head studs throughout (4 bolt main)
Ported lt4 heads
Ported lt4 intake
Comp cam ,cam (might be lt4 cam also, or a hair bigger)
BBK 58mm TB
Kooks SS headers
Has EFI 24x OB2 conversion (2002 f-body computer)
ATI balancer (brand new, 20 miles)
Newer chrome Power master high output alternator 200amp
60lb injectors
No egr junk
Comp cam roller lifters and rockers
Tall aluminum valve covers.
MLS head gaskets
Canton oil pan
Electric water pump
Poly engine mounts
Fuelab fuel regulator
ETC.. ETC.. I'm sure I'm for getting something
Rear end, ALL NEW from Randy's ring and pinion:
Bearings
Seals
Motive 3.73 gear set
Tru trac Torsion carrier
TA Performance Aluminum Rearend Girdle Cover
Suspension, ALL NEW:
Adjustable Spohn pan hard par
Adjustable Spohn lower control arms
Exhaust:
Kooks SS long tube headers
Off road Y pipe (no cats)
Magnaflow cat back
Fuel system:
Twin 255 In-tank set up (only using one right now)
Hot wire kit
Stock lines
60lb injectors
McLeod twin disk clutch
LS1 front brakes
Body:
NO rust (southern car)
After market SS Big block hood
After market SS spoiler
Roof and top of rear quarters has clear coming off (from the sun)
car is shown with the z06 wheels but will be sold with Torq Thrust II 17"wheels 275 Kumo front,
315 BFG Drag Radials (new) rear (will show pic of the wheels)
I bought this set up about a year ago and put into this roller. I've put on about 2k miles and the guy b4 me said about the same since the last time the motor was built. . .. I don't know every detail about this motor since it was built when I bought it. I do have some paper work on the build.
The clutch is a McLeod twin disk. Works perfect. I have the same clutch in my other Camaro F1a procharged. Making 675 whp and holds up flawless. The trany looks like it has been gone through at some point (I can see new gasket sealer on it) it shifts perfect.
I bought another Camaro that is all built the way I want it and will be my next turbo project so this one has to go.
7800.00 OBO!
Must sell!
Waupun WI area
nine20210944eight
call or text
may trade for a suv. Tahoe, Denali, yukon. 4x4
http://madison.craigslist.org/cto/4594090592.html
