Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
TRADES: 99 Trans Am ~Roller~ cage, 9", clean
Old 11-12-2014, 09:54 PM
pwrtrip75's Avatar
Default TRADES: 99 Trans Am ~Roller~ cage, 9", clean
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $8000
Mileage: 130000
Private or Dealer Listing: Private Listing
Location (State): WI
Color: Blue
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
~No Engine or Transmission or fuel system~
Street car, full weight, not stripped down, full interior. very nice driving car. Ive owned this car since 2004, from Texas, never seen winter or salt. Very clean underside. No rust. Paint has few chips and scratches. Not a show car but a nice looking driver.
Selling this car as a roller.
Currently it is 100% together.
I pull and keep engine, trans, fuel system,
Car includes:
-8.50 chromoly custom cage. Full view though back window, cage is semi-concealed, Removable side bars.
-9" rear end 3/4" narrower on each side, with anti-roll bar. Moser 31 spline axles, Ford Trac-Loc posi & currently has 3.00 gears. Strange 1350 yoke on rear end.
-Driveshaft included with Strange 1350 yokes on both ends (No front trans yoke) fits a TH400 and also fit with the glide I had in there. The TH400 yoke I just cut an inch off and worked fine.
-Double adjustable lower control arms with poly mount on one side. Car rides smooth and quiet.
-Reinforced control arm mounts on body.
-2" rear lowering springs.
-Stock shocks all around still.
-Custom chromoly torque arm mounts to custom trans cross member.
-Draglite wheels, 15x10 w/ 275/60/15 MT drag radials, 15x4 26" tires up front.
-Drilled and slotted brakes all around (only a couple thousand miles on them).
-Heat works.
-No AC.
-No cruise control.
-Everything else works, radio, recently replaced a couple factory speakers so they all sound good.
-Hurst quarter stick setup for forward pattern TH400/350
-Triple pass aluminum radiator stood up to clear turbo
-Racecraft chomoly tubular K-member (not a turbo one).
-VFN fiberglass WS6 hood.
-custom hidden parachute mount behind license plate.
-Battery in spare tire well with disconnect switch through bumber.
-Steel fuel tank (97-97 Fbody) with fittings welded on bottom.
-All wiring harnesses and PCM. (No engine sensors or accessories included except power steering).
Roller for $8,000.
Subtract $500 if you want the factory wheels instead of draglites
Subtract $500 if you want the factory kmember instead of the racecraft one.
~TRADES - Looking for clean fox Mustang notch or older muscle cars (Ideally a roller or a cruiser) chevelle, camaro, nova, oldsmobile 442, Corvette , Buick Grand National, T-type , old hot rod coupe, can trade up or down. NO BIKES. What do you have?? Dont let my price scare you, If its something I like maybe we can work something out.
Can deliver depending on distance.
PM me for faster reply
Janesville, WI.
Old 11-21-2014, 06:16 PM
pwrtrip75's Avatar
Trades? Looking for a mustang notch. Or older muscle car.
Also open to offers and can negotiate depending on what all you are interested in.
Old 11-21-2014, 07:00 PM
831jd's Avatar
How much power it make on the 9sec pass
Old 11-22-2014, 09:00 PM
93ss406's Avatar
Roller for roller? Tubular kmember, qa1 adj shocks,8.50 certified,10 point cage with funny car runs 9.40s all motor 2680 pounds
Attached Thumbnails TRADES:  99 Trans Am ~Roller~  cage, 9", clean-image-2982262096.jpg
Old 11-23-2014, 05:21 PM
pwrtrip75's Avatar
Not sure, never been on a dyno. It was on 18psi 18 degrees timing on E85
3680lbs (w/me) @ 141mph Calculates out to 826 according to the website below.
http://www.wallaceracing.com/et-hp-mph.php
Old 11-23-2014, 05:32 PM
pwrtrip75's Avatar
If it was stock suspension I would be interested.
Old 11-27-2014, 01:09 PM
pwrtrip75's Avatar
For trades- I want something different, had this car for 10 years, many different combos, time for change. Dont let price scare you, very negotiable if you got something I like.
Old 12-19-2014, 06:39 PM
pwrtrip75's Avatar
Bump price drop.
Old 12-19-2014, 07:45 PM
murdock.dean's Avatar
would you be interested in a 1990 mustang with 9340 original mile and less than a 100 on all new parts, text me at 315-323-8045 if so, thanks
Old 12-19-2014, 08:10 PM
codyvette's Avatar
That cage is bad ***.
Old 12-20-2014, 09:12 PM
98Camarod's Avatar
Originally Posted by pwrtrip75
Bump price drop.
I've always liked your car. Having just gotten rid of my car that I owned for 9ish years, part it out instead of selling it whole. You get more money back. I got about 2k more by parting it out. I had to use my time to take it apart and wait for everything to sell, but I wasn't in a rush.
Good luck either way man! What's next?!
Old 12-22-2014, 06:53 PM
pwrtrip75's Avatar
I dont really have the time to part it out. I want to get rid of it to get a light weight car to race. Something I can throw this engine and trans right into. The turbo on this is too small for my 370 for what I want it to do so i'd build a new kit. If I cant get rid of it i'll swap gears again, build a new turbo setup for it and run it this summer. I have my Nova im working on also, redoing the body first though.
Old 02-02-2015, 07:20 PM
pwrtrip75's Avatar
Bump. If I dont sell it or trade it in the next month i'll be building a new turbo setup for it. Really would like a different car.
Old 02-11-2015, 12:05 PM
pwrtrip75's Avatar
Don't make me do it.
Old 04-12-2015, 08:01 PM
pwrtrip75's Avatar
Really want to trade this. Bump.
Old 05-17-2015, 06:45 PM
pwrtrip75's Avatar
Negotiable. Still for sale.
Old 06-21-2015, 04:51 PM
pwrtrip75's Avatar
Still for sale/trade.
Old 08-25-2015, 10:24 PM
pwrtrip75's Avatar
bump...............
Old 08-26-2015, 10:55 AM
mikeya720's Avatar
I've got a 73 split bumper I may be willing to part with if the trades right. Located include in cleveland ohio
Old 10-28-2015, 07:49 AM
01transampower's Avatar
Pm sent
Quick Reply: TRADES: 99 Trans Am ~Roller~ cage, 9", clean
