Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
86 foxbody sbf 347 stroker afr heads built c4
Old 12-07-2014, 10:37 PM
Frank TheTank's Avatar
Default 86 foxbody sbf 347 stroker afr heads built c4
86 mustang gt clean title
strange 10 way adjustable shocks an struts
upr k member
Upr coil overs
upr caster camber plates need installed
subframe connectors
all new brakes
ford racing aluminum drive shaft
front has new wheel bearings
everything new
flaming river manual rack
Drag lites 15x8 rear mickey thompson
275/50/15
Front 15x3.5
clean wheels just needed cleaned
auto meter oil pressure trans temp water temp and 5in tach with shift light
Holley blue pump in rear
4.10 in rear end
have battle boxes need welded in
lower control arms
polyurethane tranny and motor mounts
misimoto alum radiator
black magic electric fan with tamp controller
B&m super cooler trans
BBK long tube ceramic 1 3/4
BBK h pipe
BBK subframe connectors need installed
Spintect mufflers
Stainless steel tail pipes
all 2.5
NOS nitrous plate wet kit needs Installed
with fuel pump
msd 6al
msd blaster coil
no rust on body has a bent cowl from hood flying up on me have new black cowl trim to go on
sure there more lots more
347ci stroker� 11.1 compression
Afr 185cc�
58 cc chambers
Upgraded valve springs rated to 650 lift
titanium valves
Hardened push rods
studed rockers
Pro comp 1.6 Roller rockers
Bought brand new
msd billet distributor
ford racing 9 mm plug wires
Parker funnel Web intake
Holley 750 double pumper
Headstuds
Mainstuds
Mls head gaskets
Probe flat top pistons
Eagle h beam rods
Eagle 4340 crank
All balanced to 28oz
arp hardware throughout the whole motor
Moroso 7qt oil pan
Ford racing oil pump
Custom grind cam 550. Lift
Ford water pump
Sfi balancer
Tall valve covers the thick ones
Only 50 to 100 miles on motor
C4 built to handle 800rwhp
Case fill
Lockhart dip stick
31 spline input an output shafts
Alto red clutchs
Kevlar bands
Tci 6 pinion planatary
Tci reverse manual valve body with Trans brake
Neil chance converter 4000 stall
New pump
B&m racket shifter
Has 50 to 100 miles on it also
tranny has small leak from pan where the temp sensor is
Just lost interest in the project
If you have any question and want more info call or text motor n tranny still in car so you can hear it run no expense spared
will sell motor and tranny for $4000
$6000 for everything
3 one 4 7 seven nine 6 nine seven 3
Couldn't figure out how to post any pictures
Old 12-10-2014, 01:12 AM
Bump!!!!
Old 12-13-2014, 04:20 AM
Reasonable offer won't be refused
Quick Reply: 86 foxbody sbf 347 stroker afr heads built c4
