04 CTS-V Maggied, 8.8, 8 Rib and more
Year: 2004
Make: Cadillac
Model: CTS-V
Price: $18000
Mileage: 84000
Private or Dealer Listing: Private Listing
Location (State): CT
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
Year: 2004 Transmission: Manual
Vehicle Title: Salvage
Engine: 5.7L 346Cu. In. V8 GAS OHV SuperCharged Forced Ind
Mileage:84,000 Exterior Color: Silver Interior Color: Tan
I am selling my 2004 Cadillac CTS-V due to a Job relocation. I use it as a Friday and weekend driver, garaged all other days. Never put on the track. Car made 475RWHP at 6200rpm. When I had bought the car it was stock, I put the following items on it.
Magnuson Super Charger @ 9 PSI, Rebuilt and Ported JULY 2013, 78k miles
Innovator west quick change Jackshaft and 2.7" pulley 8 rib
Stainless Works Long tube Headers 1 3/4" primaries and Cats, wrapped and painted
Stainless Works dual 3 inch exhaust
Innovators West OverDrive Crank Pulley 8 rib
Innovators West 8 rib accessory drive pulleys shrunk to run at factory spec
East Coast Super Charger tensioner
Interchiller supercharger A/C cooling
Cooling Mist Methanol injection 50/50 boost switch actuated
2 Jegs PCV oil catch Cans
K&N air filter
Alradco Aluminum Radiator
High Flow Water Pump
180* thermostat
Heads Rebuilt July 2013, 78k miles (Springs, Valve seals)
Stock Throttle Body Ported
Racetronix Fuel Pump Hot Wire Kit
Aeromotive 340LPH fuel pump
Creative Steel Urethane Motor Mounts
ACT Twin Disc Clutch
UUC Short Shifter
Creative Steel Urethane Transmission Mount
Creative Steel 8.8 Kit
-DSS 2 piece drive shaft
-DSS 1000rwhp axles and upgraded CV joints
-Ford 8.8 Cast Iron Diff Case
-Detroit Locker with 3.55 gears
-Powder Coated Red bracket
Revshift bushing
-Front Upper and Lower Control Arms Urethane 90A
-Rear Cradle bushings 90A
-Rear Upper Control Arm Bushings
Turn in Concepts Trailing Arm Bushings 90A
BMR Trailing Arms
BMR Toe Rods
Tenkin Upgraded Rear Wheel Hubs
Hawk HPS Brake Pads
Braided steel brake lines
- 3rd Brake Light upgraded neon module
-Adco Front and rear sway bars
-powergrid front swaybar end links
The car is a salvage title; not due to any real damage. When I had bought it, some guy's girlfriend found him cheating on her, so she cut up the interior and keyed the whole car. I replaced the interior, radio, and repainted the Car. It had a GM Spoiler on it, which I still have, but you will have to drill the holes.
Call or text to 203.241.6646
Does the weed-eater come with or no? Could be a deal breaker.
Also, could you please post or PM more details on the salvage title (i.e. copy of carfax, or police report, or something else)?
Oh, and nice rear end.
Below are the IAAI auction pictures. She broke into the car from the passenger side window, knifed the interior, smashed the radio, and keyed the car down past the primer. I had the Knife she used, but i threw it out. All the panels are replaced except for the sun roof cover which has one slit in it. Replaced passenger window and motor, all new seat covers/ foam/heated seats, replaced the front windshield (wasn't broken but she cuts a swastika in it). I did all the rebuilding and paint work.
