Year: 2003
Make: Chevrolet
Model: Silverado 1500
Price: $13500
Mileage: 6000
Private or Dealer Listing: Private Listing
Location (State): TN
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
The truck is a 03 silverado came with the 4.8 and 4l60e. Replaced with the turbo lq4 6.0 a stock 4l80e trans. The rear end has been built with yukon 4.10s with a Detroit true Trac locker and trick flow diff cover. The engine has the GenV floating rods and pistons with arp 2000 bolts, it has a custom grind Tick Performance turbo cam, new oil pump and timing set, ls7 lifters, trick flow 7.400 push rods, prc springs. The heads a 317 casting that have been resurfaced and fresh valve job, edelbrock pro flow intake and ls2 throttle body and 60lb Siemens deka injectors. The turbo is a magnum t76 with .96 ar exhaust housing with the Q trim impeller on a kb racing log manifold and crossover, tial 38mm wastegate and 50mm blow off valve, all 3in intercooler and piping, snow performance water/meth injection. The trans is a stock 02 4l80e, Ptc built a custom turbo stall (3000-3300). I do have a built 04 4l80e with alto clutches and steels with the transgo hd2 shift kit that was in the truck when I bought it but wasn't acting right so I changed it. It can go with the truck or I'll take a little less and keep it. The interior is in ok shape but needs the headliner replaced, has a Panasonic double din radio, the pillar has aem wide band and aem true boost gauges. The truck is a solid and very fast machine.
The only trades I'd be interested in is a very fast street car (Chevy powered)
another fast truck Chevy only.
Or a nice C5
About the only thing the truck needs is a bigger cooling fan because while sitting still it tries to heat up more than normal and the tune needs adjusted some for the new trans and stall. $13,500 located in Ramer, Tn. NO BIKES, NO BOATS, NO PROJECTS AND NO FORDS!!!
ALSO NOT REALLY INTERESTED IN TRAVELING MUCH.
