2002 WS6 Trans Am, 18,000 mi., 6-Sp, 500 HP, SOM
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $24000
Mileage: 18000
Private or Dealer Listing: Private Listing
Location (State): SD
Color: Orange
LS Engine?: Car has LS engine
2002 PONTIAC FIREBIRD TRANS AM
(Last Year of Production for the Firebird)
SUNSET ORANGE METALLIC PAINT (2001/2002 COLOR 71U)
Extremely rare!—Only 596 S.O.M. WS6’s out of 30,690 2002 Firebirds
WS6 RAM AIR PERFORMANCE & HANDLING PACKAGE
5.7 LITER LS-1 SFI V8 / 6-SPEED MANUAL TRANSMISSION
500 W MONSOON SOUND W/TRUNK MOUNTED 12-DISC CHANGER
PERFORMANCE & APPEARANCE MODIFICATIONS
SLP AIR-BOX LID
K&N AIR FILTER
SLP SMOOTH HIGH FLOW INTAKE BELLOWS
THUNDER RACING CNC PORTED THROTTLE BODY
LS-6 INTAKE MANIFOLD (STANDARD ON ‘01 & ‘02 LS-1’S, ^15HP)
LS-6 BLOCK (A RARE LS-1 GM BUILT WITH AN LS-6 BLOCK IN ’02)
THUNDER RACING 227/224 .569/.563 113 LSA CAMSHAFT
THUNDR RACING/GTP PORTED STAGE II CYLINDER HEADS
MANLEY 2.020 INTAKE VALVES
MANLEY 1.575 EXHAUST VALVES
CRANE CAMS DUAL VALVE SPRINGS
CRANE CAMS TITANIUM RETAINERS
CRANE CAMS HARDENED SPRING SEATS
THUNDER RACING HEAT TREATED CHROME-MOLY PUSHRODS
KOOKS 1¾” X 3” LONG TUBE STAINLESS STEEL HEADERS
KOOKS 3” Y-PIPE WITH HIGH FLOW CATALYTIC CONVERTERS
KOOKS FRONT 02 SENSOR EXTENSION HARNESS
SPEEDINC REAR 02 SIMULATORS
CORSA PERFORMANCE STAINLESS STEEL EXHAUST SYSTEM
SLP/HYPERTECH 160 DEGREE THERMOSTAT
ZO6 CLUTCH/PRESSURE PLATE (STANDARD ON ’02 LS-1’S)
B&M RIPPER SHIFTER
SLP STRUT TOWER BRACE
SLP DRIVESHAFT TUNNEL BRACE & SAFETY LOOP
EIBACH PROKIT PERFORMANCE SPRINGS
BMR ADJUSTABLE PANHARD ROD W/POLY BUSHINGS
TA PERFORMANCE REAR-END COVER/GIRDLE
GM 4.10 DIFFERNTIAL GEAR SET
3M INVISIBLE MASK FRONT END PROTECTIVE FILM SYSTEM
LIQUID GLASS CHEMICAL CROSS-LINKING POLISH SYSTEM
FULLY DYNOTUNED BY WOODBRIDGE DYNOTECH (490 HP)
Pictures
OK, I violated my number one rule--this WS6 never comes out of it's nest in the winter. It was 38 degrees F today so I pulled her out to take some pictures. I took 17 total, but I can only upload 10 here. I can email the others if you are a serious buyer. The sun is low on the horizon this time of year here, so they aren't the best pictures. There may be a scratch or a flaw in the upholstery somewhere, but the only issue I could find today was dust on the car, even though it has been covered with a custom car cover and stored in a very clean garage. This car has been pampered and polished and it truly looks way better than it did on the show room floor. Check out the "Last of Breed Badges, plates, and custom floor mats that are color coded to the Sunset Orange Metallic paint. You will never find a mint WS6 like this, and the SOM paint makes this car even more collectible. I'm afraid to drive it any more, as it's just too mint to risk a scratch or chip. By the way, you have to hear the rumble from the Thunder Racing camshaft, Kooks long tube headers, and the Corsa true dual exhaust system to appreciate American Muscle. Makes your hair stand up but runs on pump gas!
Corsa Exhaust 392 BHP
Heads, Cam, FLP Headers, 160 Thermostat: 471 BHP
Replaced the FLP Headers with Kooks: 485 BHP
Replaced the Cam with a Modified One After Talking with Thunder Racing: 503 BHP
It's never been raced.
OP, please don't take this as an insult, I'm only offering what I think is fair for this. Would you take $20,000? If so, I may have the OK from my wife, and could probably purchase next month...assuming it's still available then.
