2002 Z28. Forged 347, 9in T56 built
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $14500
Mileage: 82000
Private or Dealer Listing: Private Listing
Location (State): KY
Color: Beige
Transmission: Manual
LS Engine?: Car has LS engine
motor
*Wiseco Forged flat top pistons, 3.905 bore -2.2cc valve relief
with Total Seal Advanced Profiling Rings
*Eagle Hbeam connecting rods, 6.125 with ARP 8740 bolts
*Clevite bearings
*GM replacement LS7 lifters
*Texas Spd Torquer V.3 Cam 231/234 .643'/.598" on a 111
seperation.
*Texas Spd 7.40 Pushrods
*Precision Race Components 650 lift double valve springs with
TI retainers
*Meling High preformance oil pump
*LS2 timing chain and cam gear
*ARP balancer bolt
* 42lb Racetronic fuel injectors
* SLP air lid with smooth bellows
* SLP ceramic coated long tube headers
Trans
*Centerforce dual friction clutch
*Tick preformance 2,3,4 gears
*Billet keys and syncro sliding rings
*Hurst short throw shifter with leather wrapped ****
Rearend
* Moser factory replacemant 9in housing
* Moser cast iron nodular third member with aluminum pinion
support
* Moser 35 spline axles
* Strange spool
* Billet 1350 yoke
Suspension
*Comp engineering drag shocks rear
*UMI lower control arms
*Spohn rear sway bar kit with poly end links
*UMI body mounted torque arm with built in DS loop
Wheels
*15x4 front, 15x10 Weld Black RTS with MT ET radials
Misc
*AEM wideband
*Edelbrock progammable nitrous controller
*NX nitrous kit with 300hp shot solenoids
*Stock SLP loudmouth exhaust.
Dont have to sell, but the car doesnt get moved much and sits. Car is done right and needs to be enjoyed.
What heads and intake are on the motor? Stock? What gears are in the rear? Has it been dyno tuned/street tuned? Any numbers? How many times has it been sprayed?........sorry if I missed any of this work computer is crappy.
