Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
FS/FT 2001 Camaro SS Turbo 4.8
Old 09-22-2015, 03:12 PM
97_ek's Avatar
Default FS/FT 2001 Camaro SS Turbo 4.8
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $12000
Mileage: 109000
Private or Dealer Listing: Private Listing
Location (State): AL
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
2001 Chevrolet Camaro SS
109k miles
Clean Title
More pics are attached in the PDF File
Engine:
Stock Bottom End 2007 4.8 liter. Gen IV rods and pistons, 24x crank, 90k miles when installed
Lil John Motorsports Stage 1 Cam (Brand New)
243 Heads with .650 lift dual valvesprings
Trick Flow pushrods (Brand New)
LS9 headgaskets (Brand New)
Alper Motorsports Headstuds (Brand New)
Exhaust:
Huron Speed 3” Downpipe
3” Custom Exhaust Run Over Axle
Split into 2 2.5” pipes
2 Magnaflow 12866 Mufflers
6LE Centermount Exhaust Tips
Good tone, not loud at all
Fuel System: 1000 miles
Walbro 450 fuel pump, stock bucket (Brand New)
Earl’s Prolite -8 fuel feed line with Earl’s Fittings (Brand New)
Holley EFI Fuel Rail Kit with fittings (Brand New)
Aeromotive 13129 Fuel Pressure Regulator (Brand New)
Stock feed line used as return
Siemens Deka 60lb Fuel Injectors: 3000 miles
Turbo Setup: (1000 miles)
Huron Speed V2 T4 non-AC kit (Brand New)
DEI Titanium Wrapped Hotside
Turbonetics 76mm ball bearing turbo
XS Power 44mm wastegate (Brand New)
XS Power 50mm BOV (Brand New)
Dual Derale Pusher Fans (Brand New)
Autometer Phantom 2 boost gauge (Brand New)
Innovate LC-2 Wideband (Brand New)
Mighty Mouse Oil Catch Can (Draft Can) (Brand New)
Transmission:
Tick Performance Stage 2 T-56
MGW Shifter with SS race **** (Brand New)
Monster Stage 3 Clutch with Billet Flywheel
Rearend:
Strange S60 w 4.10 gears, S-trac diff, 35 spline axles (~11000 street miles, only 5 track passes)
Chromoly Driveshaft with upgraded 1350 yokes (bought with rearend)
Suspension, Wheels, and Tires:
Brand New Viking Double Adjustable Coilovers on all 4 corners (Brand New)
BMR rear lower control arms (bought with rearend)
UMI Adjustable Panhard Bar
BMR Adjustable Full Length Torque Arm w Relocation Crossmember
BMR Black Hammertone Turbo K-Member (Brand new)
Front Suspension Bushings, Ball Joints, Tie Rod Ends, Etc (Brand New)
Stock Front Upper and Lower Control Arms
Remanufactured Rack and Pinion (Brand New)
OE Wheels C4 ZR1 Black Replica Wheels
Nitto NT555 275 fronts (~15000 miles, plenty of tread left)
BRAND NEW MT ET Streets 315/35/17 rears
Interior:
Leather Interior
Reupholstered Front Buckets
Alpine Type R Speakers all around, stock head unit
The Bad:
Cosmetic:
Clear coat peel the size of a quarter on the hood
Passenger window tint crinkled
Mechanical:
Suspension rattle in right front
After downpipe was connected with rear exhaust, a popping developed under the car when the motor torques. I think a flex will stop this or open downpipe. Never happened before exhaust was added.
Slight belt or pulley squeak when the car is cold. Goes away when warmed up
This car is in great shape with a LOT of new parts. It is not perfect, but it is very nice. Currently it is tuned with HPTuners pro at 13PSI and 14.5* of timing. Based on the couple 1/8 miles passes I made this past Friday, it is making roughly 550hp at the wheels (trapped 99mph at an estimated 3600 raceweight). I am fairly firm on the price, but if you are interested just contact me and we’ll talk. The reason I am selling is I am trying to get in a better position to buy a house soon. Let me know if you’re interested. You can either text or PM me on here. 205-405-0667. My name is David
File Type: pdf
Old 09-23-2015, 07:17 AM
97_ek's Avatar
bump it up
Old 09-23-2015, 09:08 PM
97_ek's Avatar
bump, would also consider trade for a truck + cash. Would need at least 5k on top of whatever truck is offered on trade
Old 09-27-2015, 08:47 AM
97_ek's Avatar
Update: Was planning on a dyno day yesterday to get some numbers on the new setup, but I wasn't able to go. I ended up going to Lassiter Mountain last night to make a couple of passes and see what kind of mph I could get to calculate the estimated horsepower. It trapped 97mph, and using the online calculators with an estimated race weight of 3550, it would be making 530 horspower to the wheels. I have no doubt with some more passes the car could see 100 mph in the 8th with better launch technique.
Old 09-27-2015, 03:15 PM
38310ss's Avatar
Default 2001 camaro
Nice car and set up
Old 09-27-2015, 04:33 PM
97_ek's Avatar
Thank you
Old 09-28-2015, 06:56 AM
97_ek's Avatar
Bump it up. Got a couple of track passes in to get an idea on what kind of power it makes. It trapped 99 at an estimated raceweight of 3600 lbs. That rounds out to roughly 550 whp. It has at least 100 mph in it with a better launch or a two-step
Old 09-29-2015, 06:22 AM
97_ek's Avatar
sale pending
Old 09-29-2015, 04:38 PM
97_ek's Avatar
sale fell through for today, back up. Anyone interested in a very clean, well built car?
Old 09-30-2015, 11:13 AM
97_ek's Avatar
bump, price drop to 13000
Old 10-02-2015, 11:13 AM
97_ek's Avatar
bump!
Old 10-04-2015, 08:14 AM
97_ek's Avatar
bump it up
Old 10-05-2015, 01:57 PM
97_ek's Avatar
Bump it up, price drop to 12500.
Old 10-07-2015, 08:02 PM
97_ek's Avatar
No interest in a clean well built 01 Camaro. Make me an offer, and we'll talk. I'm slightly negotiable on it due to finding a house I want. I will not take 10,500 though. I've had several offers for that.
Old 10-09-2015, 10:52 AM
97_ek's Avatar
Bump it up.
Old 10-12-2015, 06:38 AM
97_ek's Avatar
bump, price drop to 12k
Quick Reply: FS/FT 2001 Camaro SS Turbo 4.8
