2000 Pontiac Firebird Formula Super Pro/Pro Racecar
Year: 2000
Make: Pontiac
Model: Firebird
Price: $34995
Mileage: 26000
Private or Dealer Listing: Private Listing
Location (State): NY
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
26,000 Mile clean Florida Car
Texas Speed 431ci LSX/LS7 632 RWHP 807 Crank HP
GM Performance LSX Race Block 4.140 Bore 4.00 Stroke
PRC CNC LS7 Aluminum Heads 403 CFM
Manley Titanium Intake and Exhaust valves,Pac Valve Springs,Jesel Shaft Rockers Diamond 14.5 to 1 Custom Forged Pistons with .043 Rings and Lateral Gas Ports
And Lightweight Pins
Callies Dragonslayer US Made Forged Crank and Rods
Moroso Deep Oil Pan w/Remote Oil Filter and Engine Diaper
GZ Motorsports Vacuum Pump System,Milodon Oil Accumulater
Performance Induction “Cary” Ported Intake w/Accufab Dominater Throttle Body
Fast 60 lb Injectors
Big Stuff 3 Computer w/Data Logging
Cam Motion Solid Roller Cam 262-270 @ .50 .710 Lift with Isky Roller Lifters
Maziere 55GPM Electric Water Pump w/Custom Ron Davis Radiater & Electric Fans
Select Lightweight Turbo 400 Reverse Shift w/Transbrake w Aluminum Drum ,Hardened Input and Output with 8” 5000rpm Circle D Convertor also comes with 2nd Convertor ATI 8” 4800rpm Stall
JW Ultrabell w/TCI Steel Trans Shield and TCI SFI Flexplate
Cheetah Shifter with Biondo Air Shifter and RPM Controller,Biondo Wizard Delay Box and Big Stuff 3 Two Step
ARE Stainless 1 7/8 /2.00 Stepped Racing Headers
Madman Front Motor Plate and Madman / Flaming River Manual Steering Rack
VFN Hinged 4” WS6 Custom Fiberglass Cowl Hood
BMR Front Chrome Moly K Member w/Tubular Upper and Lower front Control Arms w/QA-1 Front Springa and Adjustable Drag Shocks wLimiters
Aerospace front Drag Brakes
Bogart D-10 Lightweight Aluminum Wheels 15x4 front 15x10 rear w/Hoosier front runners and 30x10.5 Hoosier Slicks.Extra set of Hoosier Radial Slicks Included
Spohn Body Mount Torque Arm,Rear Control Arms and Rear adjustable Drag Bar
Moser 12 Bolt w/33 spline Spool and Axles.Richmond 4.56 Pro Gears
S&W Chrome Wheelie Bars.Custom Driveshaft w/1350 U joints
Aeromotive A1000 Fuel System all SS Braided to regulater
Montana Brothers Certified to 8.50 full Roll Cage 12 Point fuuly tied in and connected to subframes
Auto Meter Gauges and Memory Tach Shift Light
Kirkey Aluminum Race Seats(2)
Car Runs 9.40s all day in Heat @146MPH with a mild tune Naturally Aspirated
If your good at tuning MPH indicates an 8 second pass
Car located in Long Island NY Call Ritchie Shop 516 785 3086 Cell 516 661 2053
Selling for half of our Investment $34,995
