5 Second 2000 Transam Turbo Car Houston Tx
Year: 2000
Make: Pontiac
Model: Trans Am
Price: $15000
Mileage: 85000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
2000 Transam Tagged and inspected
Holley HP EFI
PT106 (106mm) with 10 passes since rebuild
Truck manifold turbo setup
Built 317 heads rated to .275 lift
ARP head and main studs
Junk 6.0 block (Cracked main cap and one scored cylinder)
Moser 9” aluminum center section 3.50 gears 35 spline axles
Anti roll bar (Below Axle)
Aerospace components rear brakes
TH400 with brake
PTC 8.5” converter
FWGA Steel Driveshaft
Pa Racing Turbo K member
Viking double adjustable coilovers and shocks
Magnafuel 4703 pro star 750 EFI pump
160# injectors
Victor JR intake
Holley 101mm TB
Air to water intercooler system with external heat exchanger and ice box
15 gallon aluminum fuel cell
10 Point cage
Kirkey Seats
5 Point Harnesses
All wiring is clean and labeled for easy troubleshooting if a problem were to arise
Headlights windshield wipers and all signal lights function properly
I will consider parting the car out but I would need the roller sold before I would consider it.
Text me and we can discuss individual item pricing
Located in Houston Tx
Asking $15k FIRM for complete car with everything I have for it. All you need is a solid short block and it’ll be back in the mid 5’s
call or text 817 925 9596
